its alive! need help!
- EVIL95XJ
- Vehicle Year: 1995
finally got my stroker fired up, first motor ive ever built and i couldnt have done it without this forum so thank you to you all
problem is, it will not idle when warmed up and i am getting alot of back fire out of the tail pipe when revved. running 24# ford injectors
Ford 24# injectors - PM me
Re: its alive! need help!
Check your distributor indexing. What year Jeep?
- EVIL95XJ
- EVIL95XJ
Im going to try and reindex it today. I was thinking that may be it but I did follow the directions to a T
- cruiser54
- Vehicle Model: Comanche
www.cruiser54.com
www.cruiser54.com
- EVIL95XJ
- cruiser54
It's almost always that on a new engine fire-up. We're always so darn sure we got it right and it's not. How do I know that? LOL. How's it run?
www.cruiser54.com
www.cruiser54.com
- EVIL95XJ
- EVIL95XJ
took the jeep for a drive last night around the neighborhood, after getting up to speed and coming to a stop it idles way down to the point of almost dying then idles back up to normal and seems alot lower in power then i expected
Give it some time on the low idle at stop issue. The PCM could be simply relearning the idle.
What injectors are you running now?
- EVIL95XJ
exactly what i was thinking/hoping forSilverXJ wrote:Give it some time on the low idle at stop issue. The PCM could be simply relearning the idle.
ford 24# i have some ford 26# i was thinking of trying
Keep your existing injectors and just allow more run time for the PCM to adapt.EVIL95XJ wrote:took the jeep for a drive last night around the neighborhood, after getting up to speed and coming to a stop it idles way down to the point of almost dying then idles back up to normal and seems alot lower in power then i expected
- EVIL95XJ
Still running a little odd and dying here and there
showtime3492
- Vehicle Model: xj
Any updates on this wouldn't mind knowingthe resolution. I am getting ready to out my stroker in and if its true to the way this jeep has been from day 1 its gonna run rough if it even runs lol.EVIL95XJ wrote:Still running a little odd and dying here and there
- EVIL95XJ
well it never seemed to be right, lower power then expected, dying when coming to a stop, finally broke down and took the timing cover off just to make sure it wasnt a tooth off, it was perfect, played with the distributor more and it was off a bit, got that as perfect as perfect can be, she smelled rich, checked the plugs and she was rich, really rich, added the map adjuster and turned it down to 3v and has been running great ever since, ive got about 500mi on the motor now with no problems of yet, really enjoying it
