head gasket options?
jason alexander
- Vehicle Model: GC
[*]hey guys im wondering whar the thickest gaskets u can get are for the 4.0 head i have seen talk about. 051 and. 043 im wanting to lower my cr any advice on what head gasket to use?
Re: head gasket options?
The old style composite OEM HG is 0.051" but I believe the new multilayer steel HG is 0.043".
Retlaw01XJ
Sure would be nice if there was a wider range of thicknesses available to fine tune our compression ratios!
Some of the turbo Buick guys used to stack the (single layer) steel shim gaskets.
Walt K
Eastern Pa
Eastern Pa
racing89
- Vehicle Model: comanche
I believe the felpro 530sd is .052" compressed. Am currently running with over 10.5 : 1 compression
Black00Sahara
- Vehicle Make: Wrangler
- Vehicle Model: Sahara
www.ferriday.co.uk/cnc/decompression_plates.shtml
check this out. not for jeeps but someone in the US could produce this......... HESCO????
You would need longer push rods and quench would be non-existent. Better just to build the engine the way it needs to be built for the intended compression.
Users browsing this forum: Google [Bot] and 7 guests
