piston dishing
amcinstaller
Vehicle Year: 1980
Vehicle Make: AMC
Vehicle Model: Spirit
piston dishing
Post by amcinstaller »
okay, probly answered a bazillion times already, but when building a stroker, why dish the pistons? is it strictly emissions, compatibility, or is there performance gains to be had. the obvious enlarging of the combustion chamber makes sense, but is there more to it?
Re: piston dishing
Post by John »
Means to achieve a desired compression ratio, if you want to run on regular grade pump gasoline, you will be watching cr closely and picking your cam carefully.
Re: piston dishing
Lowers the compression ratio while keeping a tight quench.
You could just use a thicker head gasket to open up the compression ratio but you would reduce quench.
seanyb505
Stroker Displacement: 280ci
Re: piston dishing
Post by seanyb505 »
If youre looking for a piston to dish safely you can go with the Silvolite 2229, mine have been done to 30cc, and my shop says theyre ok as far as thickness left for safe operation.
97 XJ 4.6
90 MJ 4.0 - sold
RAPTORFAN85
Vehicle Year: 2001
Vehicle Model: TJ
Re: piston dishing
Post by RAPTORFAN85 »
On a side note:
were is there a good shop that can dish my pistons and do a quality job?
any good/bad expiriences?
thanks,
jake
"Strrrrroke me, stoke me...."
Billy Squire
Re: piston dishing
Post by John »
Give Oletshot a private message, he is on this board.
oletshot
Re: piston dishing
Post by oletshot »
I'd be happy to do a set for you. I machine them to whatever cc dish you'd like and semi polish the top to help with pinging. $70 plus shipping. One thing though, it's your responsibility to determine if the web is thick enough to be safe. I'll let you know what the thickness will be before I machine them, then machine them once you OK it. Just give me a PM when your ready.
'98 XJ 2-door, '94 YJ.
RAPTORFAN85
Vehicle Year: 2001
Vehicle Model: TJ
Re: piston dishing
oletshot wrote:I'd be happy to do a set for you. I machine them to whatever cc dish you'd like and semi polish the top to help with pinging. $70 plus shipping. One thing though, it's your responsibility to determine if the web is thick enough to be safe. I'll let you know what the thickness will be before I machine them, then machine them once you OK it. Just give me a PM when your ready.
Good to know. I will be doing this somtime in the coming months.
This is why I love this site!
Billy Squire
Users browsing this forum: Ahrefs [Bot], Google [Bot], Semrush [Bot] and 1 guest
