strange change
spdrcr137
Vehicle Model: zj
strange change
Post by spdrcr137 »
So I got the stroker all put together and installed with no major issues. Got the dizzy correct and the motor was running great. I put about 3000 miles on the build and now the motor is pinging during full throttle, the motor used to run right up to redline and shift hard. Now it runs up to about 3500 and starts pinging. I didnt install an afr because it ran so good from the start. now im confused as to what could have changed.
Ideas? Suggestions?
Re: strange change
How old is your fuel filter?
spdrcr137
Vehicle Model: zj
Re: strange change
Post by spdrcr137 »
ummmm i dont know, it will be brand new after today though. I will let you know if i see any changes.
spdrcr137
Vehicle Model: zj
Re: strange change
Post by spdrcr137 »
Changed the filter with no change to the condition. I will test fuel presure at the rail this evening.
spdrcr137
Vehicle Model: zj
Re: strange change
Post by spdrcr137 »
Checked the fuel pressure and all was good 49 at all loads.
Re: strange change
Your injectors could be clogged up so try adding a bottle of injector treatment next time you fill the tank up with gas.
spdrcr137
Vehicle Model: zj
Re: strange change
Post by spdrcr137 »
Changed injecters to ford 24# built an adjustable map sset it at 5.5 and still the same issue. With 91 octane it is a very light ping at 87 it really makes a rattle.
Any ideas??
Thanks in advance
Re: strange change
What are the specs of your stroker build and what parts went into it? Is the SCR high?
Try premium fuel for now and buy a wideband O2 sensor/AFR gauge so you can find out what's going on. I know it's going to cost a few $$$ but it's still a lot cheaper than having to replace broken pistons/rings that have been damaged by detonation.
Users browsing this forum: Ahrefs [Bot], Amazon [Bot], Bing [Bot], Semrush [Bot] and 2 guests
