Thanks for the kind words guys. :rockout: A project that will never be done :cheers:
Anytime you can make a head flow better you will make more power. Providing you are matching components to optimize the flow rates.
One crude example would be;
A head that gives you an increase at a large valve opening mated to a cam that doesn't have the lift is`nt going to get you to far. Things like quench, cam dynamics, flow, thermal properties and harmonics are no strangers.
Before I got started on the stroker I looked at the entire package. From vehicle weight, gear ratio(s), normal operating RPM range, fuel etc. and created a baseline. From there designed an engine that would meet the performance specs that I was looking for.
Chassis Dyno Run
Re: Chassis Dyno Run
X2
Are you hoping that they'll spontaneously assemble themselves some day?the_wrench116 wrote:Loads of stroker! parts not yet assembled...
