air fuel ratio at WOT
Re: air fuel ratio at WOT
showtime3492 wrote:The first time i unplugged the map however it ran better
Did you unplug the wiring harness from the MAP sensor or did you just disconnect your MAP adjuster from the wiring harness? Can you show me a schematic of how you wired up your MAP adjuster? Something here isn't making any sense. :?
CobraMarty
Post by CobraMarty »
showtime3492 wrote:
CobraMarty wrote:What is your MAP output voltage with the key on engine off?
It was higher than i thought it would be it was 5.13 at the factory setting before map adjuster.
Really need some help to get this thing figured out. TIred of seeing it sit unable to move. Thanks guys! :cheers:
That is what the factory v should be on the supply voltage side. My question was what is the voltage on the signal/output side? stock with the 5.13v supply, with the key on engine off the output v of the map should be about 4.6-4.7v. If you use the map adjuster you will supply a higher v that the 5.13v so your output/signal voltage with the key on engine off will be higher that the 4.6-4.7v.
The idea with the key on and engine off- the MAP is putting out a signal voltage at 0 vacuum aas it would see at WOT. I would get a scan tool to follow these voltages of the MAP sensor.
99 XJ M62 S/C
showtime3492
Vehicle Model: xj
Post by showtime3492 »
Signal output voltage is 4.98
CobraMarty
'Signal output voltage is 4.98'
Is that with the stock 5.13v or with the map adjuster?
With your scan tool, a map signal voltage above 4.6-4.7v will force the ecu into open loop.
99 XJ M62 S/C
showtime3492
Vehicle Model: xj
CobraMarty wrote:'Signal output voltage is 4.98'
That was at stock voltage and adjusted I believe. I'm at work now ill check when I get home
showtime3492
Vehicle Model: xj
What would cause the map signal voltage to be increased like that also?
CobraMarty
Yeah, everyone says that it is a 5v reference but I think that it is at that 5.13v so that the ecu will know if the map sensor is bad if it reads above the 5.0v. It also might have to do with altitude adjustment.
99 XJ M62 S/C
showtime3492
Vehicle Model: xj
CobraMarty wrote:Yeah, everyone says that it is a 5v reference but I think that it is at that 5.13v so that the ecu will know if the map sensor is bad if it reads above the 5.0v. It also might have to do with altitude adjustment.
I am going to go over my map adjuster and its wiring when I get home. Is like to be able to figure this out I need to take my dd car off the road for a few weeks for some maintenance. And I just wanna be able to safely drive the jeep lol.
showtime3492
Vehicle Model: xj
Updates. Just wired the map sensor back to factory and tested voltage input for the "5v" and the output. They tested to 5.11v input and 4.96 v on the output. not sure why and what is going on. Also noticed the idle air control valve was making a clicking noise with the key on, then i accidentally touched an open spot on the map sensor input voltage wire to a the brake proportion valve and it grounded out and it clicked a lot and a relay on the distribution block also clicked repeatedly (probably fuel pump since the fuel pump kicked in also when this happend.
Confirmed it was the idle air control by unpluggin sensor on throttle body and repeating.
showtime3492
Vehicle Model: xj
Deleted map adjuster from equation, same issues.
showtime3492
Vehicle Model: xj
Going to look at the grounds and see if cleaning those up helps any and maybe that is why my map voltage is high.
showtime3492 wrote:Updates. Just wired the map sensor back to factory and tested voltage input for the "5v" and the output. They tested to 5.11v input and 4.96 v on the output. not sure why and what is going on.
It's not unusual for the reference voltage to be slightly above 5v. Mine is 5.05v and I have my MAP adjuster set at 5.30.
showtime3492
Vehicle Model: xj
Yeah i understand that. My output voltage however is up to 5.0 when it should be much lower. This is causing it to skip closed loop. Now today after trouble shooting all day and trying a different pcm. I have no fuel pump and 5 cel codes
p0122
p0123
po118
po113
p1492
being that all those sensors are on mostly the same wiring i am wondering if the harness is shorting out.
showtime3492
Vehicle Model: xj
showtime3492
Vehicle Model: xj
showtime3492 wrote:http://youtu.be/aQ6CsENedTY
I dont think that is normal. That is why i am concerned.
