Auto Tranny Wiring harness quest. Going On manual trans
Lexxusleo
- Stroker Displacement: 4.0
- Vehicle Year: 1982
- Vehicle Model: Cj7
I just bought a 4.0 engine with wiring harness n computer. But it's off 95 grand Cherokee auto. Will that wiring harness and computer work on manual tranny?
pepplemotorsports
- Vehicle Year: 1995
Re: Auto Tranny Wiring harness quest. Going On manual trans
It can work. I'm running an auto XJ comp and wiring in my manual XJ. You have to jump the NSS to make it start. Jeep runs fine down the road thinking it is in park at 60mph. Getting cruise to work would require a switch to trick it into thinking it is in gear. Won't do cruise in park. Might be slightly harder with a ZJ comp and the BCM/alarm depending on options but definitely usable.
yuppiexj
My '90 XJ (Renix) will keep the cruise engaged in neutral.
If you set the NSS to be in Neutral it might keep you from having to add the "I'm in park but not IN park" switch
