Not doing a stroker. Doing the head with LS1 valves. I have the 703 injectors. Along with 99+ intake. The exhaust is 2.5" from maifold to tail pipe. Not to mention hypertech III and k&n CAI.
I was wanting to do the head with LS1 valves and a cam. Is the 68-231-4 ok?
97 Cherokee XJ
68-231-4 cam ok to use?
jeep7081
- Learning to use the board
- Vehicle Make: Jeep XJ
Re: 68-231-4 cam ok to use?
Yeah, that cam will do fine but you'll need to upgrade the valve springs. If you're going to use LS1 valves, the LS1 valve springs should be suitable but check their recommended installed height and the spring pressures before you use them.jeep7081 wrote:I was wanting to do the head with LS1 valves and a cam. Is the 68-231-4 ok?
jeep7081
Is the cam worth doing? Am I going to notice the power gain?
jeep7081
It says not for fuel injection. Looks like everyone uses it though?
Its their blanket statement for the LSA. It works very well with the stock Jeep fuel injection.
jeep7081
Ordered and shipped.
jeepers1987
can you use this same cam (68-231-4) on 2001 jeep cherokee 4.0 fuel injection stock?
jeep7081
Yesjeepers1987 wrote:can you use this same cam (68-231-4) on 2001 jeep cherokee 4.0 fuel injection stock?
jeepers1987
what about 68-201-4 comp cam? with stock valve springs n valves? do i need to have it tune?
jeep7081
Ask Comp or Ryan (tuner) on here.jeepers1987 wrote:what about 68-201-4 comp cam? with stock valve springs n valves? do i need to have it tune?
jeepers1987
thanks
