4.6 project under construction
fannman
- Vehicle Model: wrangler
hey guys im new to the site and i have been lurking in the shaddows and reading alot, im new to the jeep scene but not real new to building a few motors,i have a 92 renegade that im doing the 4.6 build on right now and consists of a new scat crank 4.0 rods, arp rod bolts and a ported polished 7120 head with a comp special grind cam and harland sharp rockers, right now im back at the machine shop for a deck on the block after putting in the icon pistons and checking the deck that came up 35 thou in the hole to bring quench back up and i was also informed that the 3 thou i had the on the hone for those pistons wasnt enough,funny the paperwork said that for street use 2.5 to 3.5 was enough,so i will open it up a little more,all this started a few weeks ago with a mild rebuild and a comp cams swap that ended up with some low oil pressure readings that prompted me to pull the motor to find cam bearings wiped out after a few hundred miles,so i have made the custom solid pin and preset endplay for the cam and checked it for runout wich is ok and also had it polished, i will say that this is my second go round with this motor and hope to get it going by the weekend ,i have never seen a mix of american and metric fasteners as i have with these jeeps,anyway this sight has been very helpful.
fannman
Re: 4.6 project under construction
well she is up and running, this is round number 3 and everthing is looking ok for now,i put a cam in from 505 along with a double spring setup i had to machine the spring pockets on head to get the right install height i also put coated cam bearings in it on this build since the last build ate the cam bearings,oil pressure is ok at hot idle around 20 psi and 45 to 50 psi at 2500 rpm, this is with a a stock melling pump that i went through and polished and blueprinted, i broke the cam in on schaffer 30wt and drained it and put new filter on with rotella 15 -40 after cam was broke in,i will say it is big difference from the 4.0 that was in it,its smooth and the power is there especially right off idle and that is with 3.55 gears and 33 inch pro comp all terrains,this is day two with about 150 miles on it right now,need to get my map adjuster running my air fuel gauge is showing a little rich at wide open throttle,anyways thanks to this site and silver xj for the help,i will post later after it gets some more time on it,, later.
fannman
well i may have spoke too soon,i have about 600 miles on stroker and now i am developing a faint tap or kinda a tick from under the jeep that goes up with rpm,i put my stethoscope on it and it seems like its coming from cylinder 5 with scope on pan rail near cylinder 5,i check flex plate bolts and they are good and flexplate isnt broke its either a rod or the cam,im running 15w40 rotella with additive and have decent oil pressure when extremely hot the lowest it will go is 22 lbs with standard pump,i can run the rpms up in neutral very slowly and its there all the time and goes up with the motor rpm,so the pan will come off i guess and see whats up.this will be round FOUR if i have to pull it out
CobraMarty
- BANNED
The cam springs you used- What was the pressures? seat pressure at installed height and pressure at full lift?
99 XJ M62 S/C
99 XJ M62 S/C
fannman
Dual spring from 505 i machined the head to set them up at 1.690 .seat pressure 105 open 250
fannman
UPDATE; stroker has a couple thousand miles on it with no issues i have not had time to drive it much until recently,now im driving it daily and it just seems to run stonger,it may be the cool air and its breaking in nicely,oil pressure is good its around 50 on the road and high twentys at idle,fixing to do an early oil change and drive, drive, drive,...will update later if anything changes.later
Busey
did you locate the source of the tick ?
fannman
i did find what i thought it was,i tightend up the lash a little on rocker and it hasnt come back plus i think it is just the sound of these straight six valve trains kinda noisy
You have a solid lifter cam?
fannman
hydraulic
Just want to clear up a little terminology. Lash is when there is space between the rocker tip and valve (where is is usually measured). Solid lifter cams have lash. Preload is what hydraulic lifter cams have. No space, but compression of the lifter. The starting point for preload is called 0 lash, no space, no compression.
fannman
I tightened up preload a little,there was some room for a little more on that one and seemed to help hope its not a lobe going flat,it could be the cam had a smaller base circle on that lobe only dont know time will tell.
