Pushrod length
Stroker Ace
Where's the "any" key?
Pushrod length
Post by Stroker Ace »
I have a (what I'm told is) 97 block with a 94 head. The block has been resurfaced but NOT decked. The head has be resurfaced too. The cam is stock. Can I use stock length pushrods or do I need to order a checker and get a custom length made? Thanks.
Re: Pushrod length
How much has been taken off each?
Stroker Ace
Re: Pushrod length
Unknown. Just told it was a clean up. I bought this long block used/new with no pushrods.
JeepFamily
Vehicle Model: ZJ
Re: Pushrod length
Post by JeepFamily »
The best way is to use a push rod measuring tool. Measure the rod length at zero lash and add your preload between 0.040" and 0.060". The unit from Comp Cams is a good one and not too expensive.
JeepFamily (Rob)
1997 ZJ 4.7 Stroker
2000 WJ Limited (Totaled)
2002 WJ Limited 4.7HO (Sold)
2003 WJ Overland 4.7HO
2005 WK Limited (sold)
1997 ZJ Orvis 5.2 Up Country(48K miles)
1997 ZJ Laredo (parting out)
1998 ZJ Limited 5.9
Wrangler Want-ta-get-one
Re: Pushrod length
Agreed.. best to check it.. although if what you were told was true and barely anything was shaved.. Stock Pushrods should be fine.
JeepFamily
Vehicle Model: ZJ
Re: Pushrod length
Good point. For final verification once you've installed the factory push rods, you should achieve 1/2 to 2/3 turn from zero lash when torquing the rocker bolts.
JeepFamily (Rob)
1997 ZJ 4.7 Stroker
1998 ZJ Limited 5.9
Stroker Ace
Re: Pushrod length
Thanks everyone. Pushrod checking tool is on order.
shawnxj
I love this board
I love this board
Vehicle Model: cherokee
Re: Pushrod length
Post by shawnxj »
what's the best way to measure? from the base circle to the rocker then add preload?
shawnxj
I love this board
I love this board
Re: Pushrod length
Post by shawnxj »
anybody know off hand how long the 97+ pushrods are? the faq only lists up to 96
JeepFamily
Vehicle Model: ZJ
Re: Pushrod length
9.640 to 9.660 inches
JeepFamily (Rob)
1997 ZJ 4.7 Stroker
1998 ZJ Limited 5.9
Re: Pushrod length
shawnxj wrote:what's the best way to measure? from the base circle to the rocker then add preload?
Pretty much.
Stroker Ace
Re: Pushrod length
Used the checker. Came up with 9.525 with the 0.060" preload. We'll see how she runs. I hope I did it correctly.
Re: Pushrod length
why are you going with .060" preload?
Stroker Ace
Re: Pushrod length
SilverXJ wrote:why are you going with .060" preload?
I read on here multiple times .040 to .060. Is this not correct? :doh:
shawnxj
I love this board
I love this board
Re: Pushrod length
Post by shawnxj »
i have a pushrod measuring tool(tfs-9002) but nobody lists how much per turn it is. so can i just a pushrod and tighten it up to zero lash then but a dial indicator on it to see how much is compresses for preload? the lifters have been soaking in oil for about a year before i put them in the block last night
