change push rods after milling the deck?
titan
- Vehicle Year: 1995
- Vehicle Model: ZJ
If you mill 0.020" from the deck do you need to change push rod length to make sure the geometry is good?
- IH 392
Re: change push rods after milling the deck?
Push rod length doesn't have anything to do with the geometry, it affects lifter preload only.
x2. Milling or shimming the rocker pedestal, or moving the valve stem changes rocker geometry,
However, check your preload to see if you have the correct pushrod length.
Scottr
I have the same exact question- so..how do you check the preload?SilverXJ wrote:x2. Milling or shimming the rocker pedestal, or moving the valve stem changes rocker geometry,
Scott
- IH 392
I use a dial indicator.
