Refined Cam Sim comparisons
ruffy01
Post by ruffy01 »
I refined my methods a little & updated head flow spec's with SilverXJ's recommendation.
With each sim' run SCR was altered (cam specific) to achieve a DCR ~8.3:1.
1st up: Comp cams
2ndly: 505Performance Cams & Comp Cams 239-4
Interestingly, Comp Cams 239-4 & 505Perf Cams 263-265 14H are almost identical with this sim.
From a user POV the 505 cam could be run with stock valve springs (0.427/0.438 Lift) Vs the 239-4 (0.493/0.512 Lift) which definitely needs aftermarket.
The other spec's on these two are:
263/265: IVC=65.5*, LSA=114*, Overlap=36*
239-4: IVC=58.0*,LSA=111*, Overlap=44*
So a higher SCR with the 263/265 cam's late IVC also.
The 505Perf 272/280 14H sacrifices a little low down torque but catches very quickly with a very flat early curve. Nice HP too.
CobraMarty
Re: Refined Cam Sim comparisons
Post by CobraMarty »
The gains are mostly between 4000-5000rpm. How often are you in that rpm range? If you have an auto that shifts at 4800-4850rpm, whats the point?
99 XJ M62 S/C
FlyinRyan
Post by FlyinRyan »
I would avoid ANYTHING from 505.....
Flyin' Ryan Performance
You would get a better view if your limit the plot RPM to 5000. Enter ALL the data for the camshaft, seat to seat and .050" numbers. Then compare between the two. This will also help DD calculate the ramp rates
BDD
I think I'll order a "tab"
Vehicle Model: tj
Post by BDD »
FlyinRyan wrote:I would avoid ANYTHING from 505.....
Care to elaborate?
I havn't been on the site for awhile. I have used 505 and had nothing but great service and six cylinders that beat up v8s. Am I missing something?
I am really interested to hear what you have to say as I was concidering your tuning services. Thanks
ruffy01
Post by ruffy01 »
CobraMarty wrote:The gains are mostly between 4000-5000rpm. How often are you in that rpm range? If you have an auto that shifts at 4800-4850rpm, whats the point?
It was simply a 'have a look & see' exercise Marty :D
No good for my needs.
ruffy01
Post by ruffy01 »
SilverXJ wrote:You would get a better view if your limit the plot RPM to 5000. Enter ALL the data for the camshaft, seat to seat and .050" numbers. Then compare between the two. This will also help DD calculate the ramp rates
Thanks Silver, I did enter all the .050" data but it disappears after saving, not on all cams though :?
I shall narrow down the RPM range.
ruffy01
Post by ruffy01 »
As BDD asked, I'm also curious.
I've read negatives about their rollers but not their other profiles.
I'm still checking out other cams but I quite like 505's 263/265-14H vs Comp's 239-4:
They appear almost identical (according to the Sim' of course, real world may be different)
I could run factory valve springs with the 505 cam but not Comp's 239-4.
Search on here for 505 issues. Bad service, bad packaging, failures, etc.
As for DD not saving both the seat to seat and .050 figures I ran into that problem as well. I believe something else changes in the cam manager that has to match when you do the other figures. I can't recall exactly though.
ruffy01
Post by ruffy01 »
SilverXJ wrote:Search on here for 505 issues. Bad service, bad packaging, failures, etc.
Thanks mate.
I just re-entered the .050" data, saved, closed & re-opened; gone!
It holds the data as long as the session is open.
I've found a few negatives on 505, damn shame, I do like their profiles.
I'll look a bit closer at Erson, Hesco & Crane too.
scalper
Stroker Displacement: 4.7l
Vehicle Model: cherokee
Post by scalper »
x2
