need conformation
- vashxj
need conformation
So on my 4.6 I want .050 quench so my m/p gasket compressed is .041 so I should have my deck .009 above the piston right? I have been looking at my numbers to long
- ruffy01
Re: need conformation
If your gasket is .041" & .009" deck height then yes, quench is .050".
I thought commonly available gaskets were .043" & .051"? I'll have to check that.
- vashxj
Your right bit after Its torqued it should be .041.... I think
No, its .043" compressed.
- vashxj
ok so you want the piston .007 in the hole
If you want a .050" quench, then yes you will want the pistons .007" in the hole.
- vashxj
ok cool i have been getting everything together there is to many numbers lol but the block is almost done just need the deck
- BANNED
You are aware a tighter quench, although it does slightly raise the compression helps more? So the slightly added compression really doesn't matter, the tighter quench will prevent detention.
If your decking the block, I see now reason to keep a .050 quench? Nosigma ran his quench height at .017, this is the tightest I've ever seen run without issues to 5000 rpm. I've seen and dealt with motors with a quench in the high .02x range. 1 in the 10s for compression with a comp 231 & runs on Cali 91 pump gas.
My quench will be a even .03". .043 head gasket and the pistons are .013 above deck. I would say deck the block so your either zero deck or just above deck, tighten that quench up, you'll gain in efficiency, less chance p detonate and less emissions.
Users browsing this forum: Amazon [Bot], Bing [Bot], Google [Bot] and 2 guests
