How to disassemble head
- BANNED
Got my new core here and was curious how to I remove the valve springs, valves ect?
- 00XJ49
Re: How to disassemble head
There's a tool called a valve spring compressor that... Well you can probably figure out what it does.
If you're not worried about damaging anything, you can use a socket and a mini sledge. Put the socket on top of the retainer, and give it a good pop with the sledge - the locks should pop out (repeat until they do, should only take a couple whacks). Again, this method is not designed with any salvage in mind... If you're planning on keeping your springs and/or valves, get the compressor (should be able to rent one from Advance/O'Reilly/etc.).
"Roads? Where we're going, we don't need roads..."
- BANNED
00XJ49 wrote:There's a tool called a valve spring compressor that... Well you can probably figure out what it does.
Ya wanna keep the stuff for my engine builder. Get him some spares and what not. 40 to have a shop disassemble, hot tank, mag & hot tank again
Users browsing this forum: Bing [Bot], Semrush [Bot] and 1 guest
