Fuel tank
Zorm
Vehicle Year: 1983
Fuel tank
Post by Zorm »
Would it be worth my trouble to get a fuel tank from a 2000 tj with pump and sending unit for my 83 cherokee project?? I will be using a OB1 fuel injection.
racing89
Stroker Displacement: 306 ci
Vehicle Model: comanche
Re: Fuel tank
Post by racing89 »
Part #e8248 napa, carquest, .etc... . Inexpensive, enough fuel for 500 + h.p.(65 p.s.i. 135 g.p.h. I think) , inline with mount kit, easy hook-up, and readily available. Kind of noisy though!
Zorm
Vehicle Year: 1983
Re: Fuel tank
Post by Zorm »
Thanks racing89, I do already have an external fuel pump, Master 2800 series I think. I was just wondering if having a "all in one" unit would have any benefit, and since this is from a 2000 TJ, if it would even be adaptable to a older fuel injection system.
jonb8
Re: Fuel tank
Post by jonb8 »
2000 TJ is OBD2 with a single line system and regulator in the the tank. Yours will have 2 fuel lines off the rail, one pressure and one return out of the regulator...Won't work with your fuel rail, no place to send the fuel. You could change to a 96-01 model fuel rail and it will work but a OBD2 has a 4 wire pump plug in (not sure why) and your obd1 will be a 3 wire. Orange for power, black for ground and purple for sending unit,. OBD1 has 39lbs on the rail and OBD2 has 49lbs, also the OBD2 pump is $200.00 and the OBD1 is cheap, so I hope this helps alittle. Since it's a 83 are we talking about a FSJ with a xj drivetrain and harness?
Zorm
Vehicle Year: 1983
Re: Fuel tank
Post by Zorm »
jonb8 yes, FSJ with engine block and wire harness from a 91 xj, tranny will still be my T176.
shawnxj
I love this board
I love this board
Vehicle Model: cherokee
Re: Fuel tank
Post by shawnxj »
racing89 wrote:Part #e8248 napa, carquest, .etc... . Inexpensive, enough fuel for 500 + h.p.(65 p.s.i. 135 g.p.h. I think) , inline with mount kit, easy hook-up, and readily available. Kind of noisy though!
racing89 that part # doesn't exist on napa and leads to a in tank unit for carquest. can you double check the part number?
racing89
Re: Fuel tank
Post by racing89 »
try nfp p5000. Headed to nfld. right now. Ill look into when I get back.
racing89
Re: Fuel tank
Post by racing89 »
afp e8248 # good on prolink, napa knowhow, and by phone call to local store. I think its made by airtex.
Danial
Vehicle Year: 2012
Vehicle Make: 2012
Vehicle Model: 2012
Re: Fuel tank
Post by Danial »
Interesting discussion about fuel tank, and i really appreciate to above comments, i also want to say something about fuel tank, well recently i change my jeep fuel tank, because, first fuel tank, was damaged, and now i have change fuel tank, and now everyone thing is OK, well keep it up guys ...
