Highly PO'd at machinist
TR1Hemi
Re: Highly PO'd at machinist
Post by TR1Hemi »
I'll ask that question!
TR1Hemi
Post by TR1Hemi »
I am in North Platte, Nebraska. My choices are this guy, or another guy who does race motors, who takes months...
Try sliding the cam in backwards, if it's the front bearing you'll find out real fast!, it may?? be able to be saved?, sometimes you can wiggle it in and find the high spot and trim it a little with your pocket knife, but if it's bent to much you'll be into the steel backing before you get the babbitt dressed up.
TR1Hemi
Post by TR1Hemi »
I tried the install the front of the cam first into the first bearing and it is not tight, I also tried installing the rear of the cam into the rear bearing first and it was not tight, so if it is a tight bearing it is one of the middle two, or course you cannot check for straightness this way, but they all look straight. He is going to measure the cam then measure the bearings while in the block, and see what is up, then possibly take out the bearings and check the block sans bearings and see if one is tighter than the others, then try new bearings.
heavy equipment
I think I'll order a "tab"
Post by heavy equipment »
You could have the piston skirts knurled. I've done it several times with good results. Some 1000 hp Cummins I've worked on had Teflon inserts in the skirts parallel to the wrist pin. I've never seen it on a gasser, though.
