4.6L titan
- John
Re: 4.6L titan
Redtj35 you leaned the engine out when you lowered the voltage below 5 volts, richened when you went above, read your plugs at different areas, cruse... wot hard pull. Listen to that motor for pinging. Fuel pressure adjustments are another method of fine tuning, but that was not directly related to what you was adjusting.
Redtj35
Re: 4.6L titan
I never get any pinging no matter what. i just get a no throttle responce when i adj. the map to a certian voltage.
- John
Re: 4.6L titan
The computer may be part of this if the voltage is out of a predetermined range, it will cause faults and backup mapping.
Redtj35
Re: 4.6L titan
really? Well i may try and change my voltage a little bit tomorrow.
Redtj35
Re: 4.6L titan
1995 XJ with stock 39 psi fuel pressure. thats from that website??
- John
Re: 4.6L titan
The fuel pressure sounds about right for a 95 and will run about that unless you put in a fuel pressure regulator.
Redtj35
Re: 4.6L titan
Well recently i have been trying to set my map voltage and i guess doing it to much messed up my potentiometer cuz now my jeep is stuck at 6.70 volts and when i turn the trimmer to adj the voltage the voltage doesnt change!!!
Redtj35
Re: 4.6L titan
I have a NV3550 tranny with a stock clutch. Im just wondering if I should upgrade to a more heavy duty clutch?
Re: 4.6L titan
I wouldn't upgrade the clutch unless you see it causing some issues.
Redtj35
Re: 4.6L titan
Alright sounds good, Tomorrow im going to replace my intake/exhaust gasket. Im going to use a felpro gasket and use copper high-temp rtv to make sure it never leaks!!!! If it dont fix the ticking noise i guess it has to be a crack exhaust manifold.
- Muad'Dib
Re: 4.6L titan
Your already going to have the manifold disconnected to replace that gasket, might as well inspect it carefull for cracks at that time...Redtj35 wrote:Alright sounds good, Tomorrow im going to replace my intake/exhaust gasket. Im going to use a felpro gasket and use copper high-temp rtv to make sure it never leaks!!!! If it dont fix the ticking noise i guess it has to be a crack exhaust manifold.
Usually a mechanics mirror will reveal a crack also if there is one.
Redtj35
Re: 4.6L titan
Well its all fixed no more leaking!! Im stoked motor sounds sooo clean and nice now!! Now I just gotta tune it up for better acceleration and not so much top end. I mean when i had my 4.0L stock my jeep would maybe top out at 85. Now with the stroker I can probley get up to 105!! haha
AlexTJ
Re: 4.6L titan
Sounds dangerous lolRedtj35 wrote:Well its all fixed no more leaking!! Im stoked motor sounds sooo clean and nice now!! Now I just gotta tune it up for better acceleration and not so much top end. I mean when i had my 4.0L stock my jeep would maybe top out at 85. Now with the stroker I can probley get up to 105!! haha
Redtj35
Re: 4.6L titan
Alright now the stroker is running awesome!! It just seems I cant get it tuned for more acceleration and less top end. Ide Rather have the motor scream 1st-3rd gear than 3rd-5th. Any ideas on what i should adj. Or maybe even hotter plugs?
Re: 4.6L titan
If your AFR is good you won't be able to change the tune like you are seeking by playing with the MAP sensor adjuster. The only way that I know of is to change the valve events. I.e. Advance the cam a few degrees, or change the cam for one that gives you the curve you are looking for. BTW, what cam are you running?
Users browsing this forum: Amazon [Bot], Semrush [Bot] and 2 guests
