wide band sensor placement
				rammit11
Hi , getting to the last few things to do before starting my 4.6 for the first time. I was wondering where to install the sensor for the wideband in the head pipe. I have a '98 xj and was looking to put it on the engine side  right before the large bubble like area in the pipe( is this a good area or would there be a better place?).
						- Muad'Dib
Re: wide band sensor placement
It doesn't have to be put in a specific spot; meaning it doesn't need to be x inches away from y etc.
Just make sure you get it as close to the head as possible but still in the exhaust stream after all the exhaust streams meet.
Keep in mind, if you ever have to change out your exhaust manifold and you put it on there you will have to get a bung welded on again. I put mine in my front pipe right after the exhaust manifold bolts to it. No problems with mine.
				rammit11
Thanks Maud'Dib  that is the general area I was thinking about I just have to go a little  further down the pipe as the front  o2 sensor is in that location already and keep everything in the clear from the front drive shaft.
