roller rocker ratio for a 4.6
- Vehicle Year: 1969
- Vehicle Model: commando
I have a set of 1.5 and 1.6 ratio roller rockers I'm wondering if they'll work for my motor.. any one help.. thanks
Re: roller rocker ratio for a 4.6
What are they from? I don't know of any roller rockers made for the 4.0L that were 1.5:1 ratio. Usually 1.6:1 or 1.7:1.
There chevy 350 roller rockers. I only paod 75 for them. But I might have a different ratio rocker I forget what ratio there are Ill check tonight
Unless you can do a whole bunch of machine work they won't work. You simply can't bolt on any rocker.
My brother works at a machine shop so Id have to drill the rocker arm bolt out and tap it to the arp size but I was woundering what ratio do I need.
1.6:1 ratio. However simply drilling and taping the boss for a stud is not the solution.
Sell them back and get a refund. The 350 SBC rockers won't work on a Jeep I6,goincommando wrote:There chevy 350 roller rockers. I only paid 75 for them.
- Vehicle Year: 1993
- Vehicle Make: JEEP
- Vehicle Model: CHEROKEE
SBC rocker arms are way too short from the pivot to the valve tip. You'd have to relocate the studs closer to the valve on a 4.0 head platform to get them to contact correctly.
Yeah I got jeep 4.0 rollers now.. just need to figure out the wiring now
