So you have to order both kits to get a direct replacement? I wasn't clear on that and ended up getting the Fel Pro kit.SilverXJ wrote:Head bolt kit: 146-3601 or head stud kit: 146-4201
ARP main and head bolts
Knoxes
- Vehicle Model: GC
Re: ARP main and head bolts
2004 WJ 4.7L HO
2004 WJ 4.7L HO
They don't make a direct replacement with the studs and pins on the bolts. And you don't want to mix studs with bolts. One or the other.
Knoxes
- Vehicle Model: GC
I'm obviously confused. Isn't the pic posted by hoghunter a mix of studs and bolts? That's exactly what my stock set looked like.
2004 WJ 4.7L HO
2004 WJ 4.7L HO
That is a stock set. There are no studs. They are bolts, some with stud style heads, which does not make them studs.
