What year is my crank case?
Uncle Dude
- Stroker Displacement: 4.0
- Vehicle Model: wrangler
I bought a 90 wrangler with a 4.0 in it, the number between #2 and 3 cylinder is stamped 002CLI3 on spark plug side on the machined surface, and 3235444 cast in the block under the intake.
- amcinstaller
- Vehicle Year: 1980
- Vehicle Make: AMC
- Vehicle Model: Spirit
Re: What year is my crank case?
you can find that info and much more in our faq section. heres the blocks faq link:
http://www.jeepstrokers.com/forum/viewt ... ?f=34&t=52
Uncle Dude
from what I'm gathering from 002CLI3 is
0 = 2000
02 = feb
c = 2 barrel, but it is fuel injected [ I may be reading this wrong ]
l = 232
3 = 3rd day
EF3235444 don't match anything
0 = 2000
02 = feb
l = 232
3 = 3rd day
- IH 392
I read it as 1990, February, 258ci 2v, 13th day.
3235444 is the casting # for a '83-'90 258 block.
It is PORT injected??
Uncle Dude
I did some research and it turns out I have a 4.2 with a mopar mpi performance kit.
I6FAN
- Stroker Displacement: 4.2
- Vehicle Year: 1987
x2 on IH 392's read on this. "C" was for 258/4.2l and "M" was for 243/4.0l. Not sure where you're getting the "L" from?Uncle Dude wrote:from what I'm gathering from 002CLI3 is
0 = 2000
02 = feb
l = 232
3 = 3rd day
If you have the fuel injection, someone put it on the 258 (could have been the Mopar retrofit or DIY), or you have the 4.0l head and fuel injection. Now it would be good to know if you have the 2686 RENIX head and FI, or the 7120 head with OBD1......or even a later head and system.
- IH 392
See if you can find the casting # on the head and post it, I'm curious too.
Uncle Dude
where can I find the casting # on the head?
The intake manifold is part# is 5300235, with 11596 under it if that helps.
I'm seeing a solid L as the 5th character on the block??
I6FAN
The casting number on the head is usually on the top of the intake/exhaust flange just outside the edge of the valve cover.
