4.6 renix 1, 3,and 6 have no spark
jbxx
- Stroker Displacement: $.6 mistake?
- Vehicle Year: 1986
- Vehicle Model: CJ7
Re: 4.6 renix 1, 3,and 6 have no spark
You did remember to reattach the ground strap from the block to the firewall?
92tank
- Stroker Displacement: 4.5
are you sure you have the right cap and rotor i know the newer ones have have different cap and rotors
Could the distributor be work enough to move the rotor too far away from the non firing plugs?
racing89
- Vehicle Model: comanche
By chance did you put the wrong flywheel on? A 91-97 flywheel on a 87-90 renix will cause the exact symtoms you have.(Been there. Done that)
justjerald
Yes came off of my 89 renix block I used not to mention it wasn't doing any of this when I spun the bearing the only problem I had be for was it would cut off while I was driving sometimes so I replaced the harness and that problem went awayracing89 wrote:By chance did you put the wrong flywheel on? A 91-97 flywheel on a 87-90 renix will cause the exact symtoms you have.(Been there. Done that)
justjerald
I know its 2 years later but that was the issue!91JeepMJ wrote:Make sure your distributor is properly indexed and if it's an automatic make sure you didn't damage the flex plate when installing the engine.
cruiser54
- Vehicle Model: Comanche
Which was it?
www.cruiser54.com
www.cruiser54.com
justjerald
The flex platecruiser54 wrote:Which was it?
cruiser54
Damaged or wrong one?
www.cruiser54.com
www.cruiser54.com
justjerald
Damaged nothing visablecruiser54 wrote:Damaged or wrong one?
Now im having a similar problem
jonb8
I just saw this and it's old but I bought a jeep that wouldn't start after motor swap. It was only firing on 2 cyl and it ended up being a renix flywheel on a HO motor.. The PO swapped a renix block in and didn't change the flywheel. It had me scratching my head for some time....LOL
justjerald
Yea it sucks when spend a bunch of money on parts and then You find out your one tooth off on your distributorjonb8 wrote:I just saw this and it's old but I bought a jeep that wouldn't start after motor swap. It was only firing on 2 cyl and it ended up being a renix flywheel on a HO motor.. The PO swapped a renix block in and didn't change the flywheel. It had me scratching my head for some time....LOL
cruiser54
justjerald wrote:Yea it sucks when spend a bunch of money on parts and then You find out your one tooth off on your distributorjonb8 wrote:I just saw this and it's old but I bought a jeep that wouldn't start after motor swap. It was only firing on 2 cyl and it ended up being a renix flywheel on a HO motor.. The PO swapped a renix block in and didn't change the flywheel. It had me scratching my head for some time....LOL
Are you serious? Bummer.
See Posts 12 and 13 in my link below.
www.cruiser54.com
www.cruiser54.com
