I'm gathering parts to do my stroker, so far i have 4.2 crank and 4.2 rods. I've got dibs on a 92 cherokee engine that will be block and head. I'm going to try to keep everything for the RENIX injection (as i have not heard of any vast improvements from one to the other) and my wrangler is already wired for renix as that was my last engine swap (went from the 258 to 242 in my 87 wrangler). I've learned a WHOLE lot from this website already, and enjoy reading about everybody's stories.
Anywho, now on to my problem. When i did the F.I. swap in my wrangler, i used the HESCO HES8790ED crank position sensor relocation kit. I set the sensor to the recommended .010 to .015 (i think i used .013). The engine would start and idle, but wouldn't rev over 1500 RPM. After checking over several things, i set the crank position sensor at .010. I was able to get 2000 or so RPM out it. I took the sensor down to about .003, and now i get 3500 RPM out of it, but thats it. It acts almost just like a rev limiter. The tach will bounce up and down and the engine stumbles and pukes. I adjusted the sensor left and right to try different timing adv/retard settings but it didn't help. Hesco even sent me another kit to try to see if the pulley was manufactured incorrectly. It acted exactly the same.
1
Has anybody else experienced this situation or have any advice to offer? I'd love to be able to get 4500-5000 RPM out of it. Thanks!
