Broken Stroker, Crank end play is 1/8" out of spec. Help
Re: Broken Stroker, Crank end play is 1/8" out of spec. Hel
I wonder if the crank was out of spec...thrust bearing surface too wide. I have read that some of the scat cranks have been out of spec (bearing surfaces).
- DaemonForce
- Stroker Displacement: 4.7L Super
- Vehicle Year: 1983
- Vehicle Make: American
- Vehicle Model: Eagle
That crank is definitely out of spec. Next time pull one from an AMC.
,__,_____,__, ~A-M-C YA!
//___}/,_ll,_\__\,_____
,l_/¯\_l__ll__l__/¯\(¤≡¤)
(o))o)) (o))o))
(o))o)) (o))o))
Phman9
My first 4.6 build was done by western engine supply. I got it back with the lower and upper end assembled. I did not see the thrust surface on my first build. New crank and bearings are in. New engine sounds amazing. For sale! 2001XJ Limited 4.6 stoker.
Users browsing this forum: Amazon [Bot], Bing [Bot], Google [Bot], Semrush [Bot] and 3 guests
