but i noticed that if i give it quarter of a throttle it goes strait to the 5200 rev limiter without a problem.
and if ill give it half a throttle or more its doing that curst fuel cut at 4300.
sly-jeeper wrote:hmmm is your map causing the fuel pull under boost? im sure you thought of this already. its just strange it does it under heavier throttle
sly-jeeper wrote:has it ever ran right with the supercharger on it?
SilverXJ wrote:I'm running a 30-1913 without issue on my stroker. We should be running the 1913 and it has the correct injector drivers for the Jeep PCM.
So, are you OBD1 or 2, and is your vehicle an ex military vehicle? That could be very important clue as most military vehicles are equipped with speed limiters which could be even lower than the 100 mph that turbojeeper has brought up.atias wrote:
i have the 30-1913 too, its the one for all OBD2 jeep (you taught me that
but all the jeeps around here are old OBD1 sbec ecu (ex military jeeps), so they both work ok.
