my long drawn out street/strip xj build
vashxj
Re: my long drawn out street/strip xj build
Thanks a lot, I'm still fighting a losing battle with rust but im looking to swap everything to a 2 door
vashxj
well I came up with this winters list of projects, i need to be a little more involved with the thread. i do a lot to it but i always forget to take pics a document. so the next things are a 2wd aw4 swap and im installing a shift kit and high stall convertor. also swapping my rear end to a 3.73 and doing the trac lok clutches. i told my gf i wanted my 2nd n2o bottle and heater for christmas
then just have to order my new race tires 275/50/15 for the back and 225/60/15 for the front. slicks is now a must i just cant get traction when spraying
the_wrench116
mind telling me how you lowered it? I have a lift on mine but ive toyed with the idea of making it a cone killer.
sly-jeeper
- Vehicle Year: 1994
dou you have any dyno numbers? or track times? and seems like 3.55s would be sweet for that set up I wouldn't be surprised if 3.73s are to low
vashxj
it was not very easy, basically I have a chevy blazer bastard pack and 1in lift shackles on the back but I took a d35 zj axle and cut all the mounts off. welded some leaf perches on the bottom so the axle actually sits on top of the leafs. I have 98 Durango shock mounts in the rear and running 99 chevy astro shocks. The front I just cut the coils until I liked the height. I had to cut the studs off the front sway links and cut the bump stops cuz they were hitting. Running 99 ford explorer shocks up front. Now that im swapping it to a 2wd I will be putting the stock shackles back in and dropping the front more. I know I ran into more minor issues but got most of them fixed. There should be some more pic on cherokeeforum if you as a memberthe_wrench116 wrote:mind telling me how you lowered it? I have a lift on mine but ive toyed with the idea of making it a cone killer.
vashxj
I have not been to the dyno yet and the last time I went 14.11 in the 1/4. but it was on street tires and still slipping a lot when I hit the n2o. but I just picked up some slicks and swapping out that aw4, there should be a big difference alone. You may be right I have had many of my friends say run 4.10 but that's crazy, with 26in tires if I do any normal driving it will be at 3k rpm going 55mph. I figured 3.73 was a good medium I would like to get a tire off the ground eventuallysly-jeeper wrote:dou you have any dyno numbers? or track times? and seems like 3.55s would be sweet for that set up I wouldn't be surprised if 3.73s are to low
vashxj
forgot to say no more auto I picked up a 2wd ax-15 already and all the parts for it except the clutch and short throw
sly-jeeper
don't break it in half!...I run 3.55s on 33 inch tires with the aw4 and it really isn't bad on the street but im sure I would be much happier with 4.56s around 2200 is a good highway cruise rpm cam depending
sly-jeeper
if it was me I would keep the aw4 I bet you wont even use 1st on the ax-15 and bet you break axels when it hooks
sly-jeeper
your ride is off the wall sweet tho
vashxj
Thanks a lot, and I plan on breaking some stuff next time. I wont be happy til I at least touch 12.99
sly-jeeper
I bet you will once it hooks...I work at a drag strip lol
sly-jeeper
im about to put my stroker together i have ic944's and mopar 29 cam im seriously considering spraying...i need some recommendations! do you have any?
vashxj
im running the zex system. they are the only ones that I have seen use this control box, the box will shut off if there is a drop in fuel pressure. I think they are one of the safest ones out there
sly-jeeper
what zex kit are you running,do you have a build thread with motor specs? ive never built a spray motor before and don't know what i should be going for like as far as compression and cam choice
