injectors for my 4.7 stroker
- vashxj
Re: injectors for my 4.7 stroker
or you could use 00 ford Taurus 3.0 injectors (ev6) direct fit. on our fuel rail they are 27lbs. mine runs 14.5 at idle and about 10.5-12 at wot. great power bad mpg but who builds there for good mpg lol
- darkcorp
- Vehicle Make: JEEP
- Vehicle Model: GCh 4.0
What do those Accel 24lb'ers look like? Is it ACC-150124?
- Vehicle Year: 1985
- Vehicle Model: CJ7
Which 3.0? DOHC? Why would a 3.0L have injectors big enough to feed a 4.6L?vashxj wrote:or you could use 00 ford Taurus 3.0 injectors (ev6) direct fit. on our fuel rail they are 27lbs. mine runs 14.5 at idle and about 10.5-12 at wot. great power bad mpg but who builds there for good mpg lol
- vashxj
I know they come on the 2000 Taurus and sable 3.0 I forgot the part number, I can look at mine this weekend. and not sure why they put those in there, ford runs lower fuel pressure so it like 25lbs on the Taurus but at our 49psi its 27lbs. they work great on my 4.6, plug right in no changing connectors and they are 4 hole like the neon ones. it runs slightly rich with them but they keep up with nitrous. cool thing is the fords are such piles of crap you can find a lot of these in the junk yard and just forget you put a couple sets in your pocket on the way out..... $100+ new injectors vs risking used for free
They are <$20 /each new at Rock Auto for either 3.0, I just want to make sure they are the right ones. Thanksvashxj wrote:I know they come on the 2000 Taurus and sable 3.0 I forgot the part number, I can look at mine this weekend. and not sure why they put those in there, ford runs lower fuel pressure so it like 25lbs on the Taurus but at our 49psi its 27lbs. they work great on my 4.6, plug right in no changing connectors and they are 4 hole like the neon ones. it runs slightly rich with them but they keep up with nitrous. cool thing is the fords are such piles of crap you can find a lot of these in the junk yard and just forget you put a couple sets in your pocket on the way out..... $100+ new injectors vs risking used for free
- vashxj
the ones I got are ford YF1E-A2C they are grey and they are 26lbs on ours I just looked through my notes I have numbers written everywhere
Its not just about the flow rating. You also have to take the fuel pressure into consideration as well as the fact that the PCM is programmed to run those specific injectors.RenoF250 wrote:Which 3.0? DOHC? Why would a 3.0L have injectors big enough to feed a 4.6L?
Users browsing this forum: Semrush [Bot] and 3 guests
