roller rockers
mountaineerjeff
Stroker Displacement: 4.0
Vehicle Year: 1999
roller rockers
Post by mountaineerjeff »
I've seen all the threads on rockers and they all kinda end the same way. Mostly inconclusively....I'm looking into running 1.7 ratio rockers, but have been told that there is an issue making them work in the 4.0 head. Has anyone ran 1.7 rockers in a stock head?
build thread http://www.cherokeeforum.com/f46/offici ... ep-179516/
N/A 14.9@89
N2O 12.7@104
Re: roller rockers
I don't know who says they won't work but I know of several people running 1.7:1 ratios on stock heads.
I6FAN
Stroker Displacement: 4.2
Vehicle Year: 1987
Re: roller rockers
Post by I6FAN »
I think YellaTerra actually makes a 1.7 ratio as well as the stock 1.6.
jeepxj3
Vehicle Model: xj
Re: roller rockers
Post by jeepxj3 »
I tried and can't find any YT 1.7 RR available for sale. Does anyone have a source?
CandyCaneXj
Vehicle Year: 1994
Re: roller rockers
Post by CandyCaneXj »
Anyone know if the renix valve springs can handle the same lift as the ho valve springs?
mountaineerjeff
Vehicle Year: 1999
Re: roller rockers
I just tried to order a set from Harland Sharp and I was too that the angle caused by the ratio change can cause the push rods to contact the head. But I have never heard of this, and the rep had not seen it first hand...so here we are.
N/A 14.9@89
N2O 12.7@104
Re: roller rockers
Ahh.. that is understandable considering that the pushrod side is probably shortened to accomplish the ratio change. If this happens it would be simply a matter of removing a bit of material from the head. There is enough to remove, however you would need to pull the head. I have never heard of anyone having these issues though. It will also depend on the camshaft as well.. higher lift will pull the pushrod closer to the driver side of the head.
mountaineerjeff
Vehicle Year: 1999
Re: roller rockers
Well I was hoping to find someone with first hand experience running them on a stock cam...I'd hate to buy em and not use em...cause if I pull my head, I'm doing pistons and a hesco head. And I really am not trying to spend that much right this sec.
N/A 14.9@89
N2O 12.7@104
Re: roller rockers
I don't see a problem with the 1.7 rockers on a stock cam. In fact the majority of the 1.7s are on a stock cam just because its an upgrade that requires little unbolting.
mountaineerjeff
Vehicle Year: 1999
Re: roller rockers
That's what I thought, but then why would the rep try and talk me out of them? Doesn't make any sense.
N/A 14.9@89
N2O 12.7@104
jeepxj3
Vehicle Model: xj
Re: roller rockers
Post by jeepxj3 »
Does HS make a set of 1.7 for the 4.0? Part Number?
mountaineerjeff
Vehicle Year: 1999
Re: roller rockers
They dont have a part number. I called them directly to get them to make me a set and they recommended I research the subject before buying something that won't fit.
N/A 14.9@89
N2O 12.7@104
CandyCaneXj
Vehicle Year: 1994
Re: roller rockers
I talked to them a few months ago the guy said he could make any ratio you wanted but he was convinced anything over 1.6 would require head work. They wanted $550 for a set of 1.65 ratios :shock:
mountaineerjeff
Vehicle Year: 1999
Re: roller rockers
That's been my exact same experience. I was totally all for paying for a set, but not if they aren't gonna fit/work.
N/A 14.9@89
N2O 12.7@104
Re: roller rockers
Worse case you pull the head and do some grinding on the pushrod holes.
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 1 guest
