Recommend a stroker for a 4500 Ultra4 Jeep
jeepxj3
Vehicle Model: xj
Re: Recommend a stroker for a 4500 Ultra4 Jeep
Post by jeepxj3 »
hurleygo3 wrote:Well I killed the Hesco stroker :mrgreen: Got about 50 miles out of her.
SCAT crank
SCAT forged rods
Set of custom Diamond pistons to get a zero deck height
Losing a FP and going lean would do it, that sucks.
That is just what I am interested in, the custom Diamond Pistons for zero deck height. What will the specs be? Group buy?
That is what Scat should sell instead of the 944s in their kit.
Stroker Displacement: 4.9
Post by jsawduste »
SCAT crank
SCAT forged rods
Quoted for truth. :idea:
6TIME
Consistent
Consistent
Vehicle Year: 1993
Vehicle Make: JEEP
Vehicle Model: CHEROKEE
Post by 6TIME »
hurleygo3 wrote:SCAT just released rods.
Capscrews! :mrgreen:
hurleygo3
Where's the "any" key?
Post by hurleygo3 »
SCAT crank
SCAT forged rods
Yes it sucked. Had 2 brand new pumps that failed. That system is already being addressed. My fault for not having a gauge. That has also been addressed.
When I get the specs on pistons I will share the info. SCAT could've made a perfect kit if they went with a different piston setup. But SCAT has been easy to work with and I had the parts the next day after ordering them.
jsawduste on here has been a lot of help getting this motor built. I've learned about these motors and what does and doesn't work. This build may take a few months, but there will be no short cuts.
hurleygo3
Post by hurleygo3 »
Well I'm back to building the new motor, with a ton of help from John (jsawduste) It should be a very solid motor with great power. Waited as long as I could for a head to be released, but time has pushed me to build a 7120 head. Nothing crazy. Stainless stock size valves, springs from Hesco and roller rockers. Also a Hesco H-274 cam. SCAT crank and rods and Diamond pistons. Hope to have the pistons ordered in the next two weeks.
John and I have been talking about a fell little things that should help with cooling and fuel issues. This motor will see long periods of WOT. So keeping fuel to #6 and keeping it cool are 2 of my biggest concerns. I'll post of some pics of the fuel rail when I get back.
Post by jsawduste »
:rockout:
hurleygo3
Post by hurleygo3 »
Well I finally think I have this motor dialed. I have a few trips on it now. The power is crazy. Comes in hard at 3k and pulls till 5500 rpms. Big thanks to John Edwards, Chris Jensen [email protected] and Russ Pottenger.
The motor is built to the spec's John recommended. Russ did the head work and Chris did the tune. I had a Hesco stroker, with their aluminum head before this motor. The power is night and day difference. This motor pulls so hard on the top end. I truly can't believe the power. I was out this weekend with a few friends. I was able to pull away in the dunes on my buddy in a 4k buggy with a Turnkey 6.0l.
jeepxj3
Vehicle Model: xj
Post by jeepxj3 »
What are the final specs of the motor?
Crank, rods, pistons, CID, CR, deck, quench, head, cam, injectors, ECU, headers, intake, etc.
hurleygo3
Post by hurleygo3 »
95 block, .040 over zero decked and line bored, ARP studs
7120 head cleaned up by Russ at Bishop-Buehl. Stock valves, Hesco springs, Harland Sharp rockers, Comp pushrods
SCAT forged crank, SCAT rods and JE pistons 19cc dish
Complete assy was balanced
HV Melling pump
Hesco H-274 cam
CR 9.65
Quench .043
24lb Ford injectors
Stock ECM flashed by Chris Jensen
Banks headers
2000 intake with BBK 62mm TB and AEM spacer.
OBDII coil pack system
Post by jsawduste »
hurleygo3 wrote:Well I finally think I have this motor dialed. I have a few trips on it now. The power is crazy. Comes in hard at 3k and pulls till 5500 rpms. Big thanks to John Edwards, Chris Jensen [email protected] and Russ Pottenger.
Thanks Mike !! :worship:
LS engine are over rated LOL
