2001 jeep cherokee tuning
Xj01
- Stroker Displacement: 4.0
Hey guys, new to this forum. I have a 2001 cherokee 4.0, does any one offer any real tuning like SCT hand held tuners? Thanks!
Re: 2001 jeep cherokee tuning
Yes. Contact Chris at [email protected]. He does a great job.
Xj01
Do u have an sct tune on your jeep?
yes.
wjtom
- Vehicle Model: wj
Id use flyin ryan but that just me.Absolutely great results!!!!!!
Xj01
I've contacted both of them
it's looking good
Retlaw01XJ
I should have my '01 done too. Runs pretty good, but has a rough cold start-up and lo rpm isn't very smooth.
What's the expected cost for a tune?
Where are you guys with the mini-cat exhaust manifolds installing the O2 senor? There's practically no room to add one before the mini-cat.
I tried replacing the original and feeding the signal from the AFR gauge back to the stock wiring, but it resulted in O2 sensor error codes every few days, even with a dummy O2 sensor heater wired in.
Walt K
Eastern Pa
Eastern Pa
An large duration cam can throw the PCM a loop... as well as incorrect sized injectors. Cost is typically around $300 + SCT if you want to go that route.Retlaw01XJ wrote:I should have my '01 done too. Runs pretty good, but has a rough cold start-up and lo rpm isn't very smooth.
Thats what i would have recommended.. do you know the code?I tried replacing the original and feeding the signal from the AFR gauge back to the stock wiring, but it resulted in O2 sensor error codes every few days, even with a dummy O2 sensor heater wired in.
Xj01
Retlaw what all do I have done to your engine?
Retlaw01XJ
Mild 4.6 build with Icon pistons, Crower 44243 cam, a little head porting on a 2004 head, stock exhaust to a Borla cat-back system, and still stock air intake. Injectors are Neon 784's that are a little lean at start-up until the injector heater warms up (about 1 minute)....that seems to cause injector heater codes, and sometimes a misfire code. Happens more in winter that summer.
Which SCT product will work with a Jeep? I do have an Innovate Motorsports AF gauge I can do data logging with.
Thanks.
Thanks.
Walt K
Eastern Pa
Eastern Pa
Xj01
[email protected] contact Ryan I've been talking with him to get my jeep tuned with a real tune ! Believe it's a SCT 3200 but it's no good unless u get a custom tune installed in the device.
