Crank Nose Length
jeepxj3
Vehicle Model: xj
Crank Nose Length
Post by jeepxj3 »
Scat's new crankshaft 9-4.2L-3895, it says it has a 2" nose.
Will this length work without a spacer?
What is the length of the Jeep 242 crank nose? does it depend on the year?
WJomkcin
Vehicle Year: 2004
Vehicle Model: WJ
Re: Crank Nose Length
Post by WJomkcin »
I know on my WJ the nose is 2" and i'm pretty sure it's the same for all 242's, so you won't need a spacer. Hope that helps.
jeepxj3 wrote:Scat's new crankshaft 9-4.2L-3895, it says it has a 2" nose.
The '71-'86 258 cranks have a 64mm nose, while the '87-'90 258 cranks and the 4.0L cranks have a 54mm nose. Looks like you have an '87-'90 258 crank so you won't need a spacer.
jeepxj3
Vehicle Model: xj
Post by jeepxj3 »
Thanks, that helps.
