my long drawn out street/strip xj build
vashxj
Vehicle Year: 1999
Vehicle Model: cherokee
Re: my long drawn out street/strip xj build
Post by vashxj »
I just built the 4.6 low buck with 30 over icon pistons, 4wt crank, and 231 comp cam. I only added a few extras to the blueprint. I ported a 7120 head and used stainless 1.56 exhaust valves, ceramic header, hs rockers, and 3.0 ford Taurus injectors. my compression should be 9.6. the n2o kit I believe it zex 82021 its a v8 kit
vashxj wrote:I only added a few extras to the blueprint.
What do you mean you added something to the blueprint?
vashxj
Vehicle Year: 1999
Post by vashxj »
my engine is the same as 4.6 low buck except icon pistons (same company) 1.56 ex valves (which isn't much), hs rockers, header, 2.5 exhaust, bored tb, and ford 3.0 injectors
sly-jeeper
Vehicle Year: 1994
Post by sly-jeeper »
not much different than what im planning then...
vashxj
Vehicle Year: 1999
Post by vashxj »
just found out last night my friend ordered his new s/c for his mustang so I should be getting his old one from him soon, don't think ill get to installing it this year though still getting all my trans stull together and I need new windows on the house lol
vashxj
Vehicle Year: 1999
Post by vashxj »
starting on swapping gears, installing pedals, clutch master and removed the hitch, got the slicks mounted
vashxj
Vehicle Year: 1999
Post by vashxj »
got the pedals switched, installed clutch master and 4x4 hole covered up
vashxj
Vehicle Year: 1999
Post by vashxj »
pretty much done took it out for a few cruises and holy crap at the torque it has now
beiwulf
Vehicle Year: 1995
Vehicle Make: ZJ
Vehicle Model: Laredo
Post by beiwulf »
I just love looking at your street machine. Sweet ride and sounding even more like the performer it appears to be.
Let us know the next track times you lay down. Looking forward to hearing/reading it!
Don't use those 3M scotch locks on any surface that needs to be flat. Cylinder head, block deck, brake rotors, clutch surfaces, etc. They do way more damage than good. Not to mention the abrasive crap they throw off into cylinders.
vashxj
Vehicle Year: 1999
Post by vashxj »
I know what your talking about silver, I just used a surface prep one I had after I machined the flywheel to clean up some surface rust. I do use them a lot at work, haven't had any problems yet but I heard some guys did. guess its just how hard you push
even the surface prep ones damage the surface. Many use them and many blocks and heads need to be resurfaced because of them.
vashxj
Vehicle Year: 1999
Post by vashxj »
a little update........... got the speedometer working, didn't notice the speed sensor is offset. just have to switch out the oil pressure sensor to a 2 wire one and finish up the front axle. also going to pick the s/c up next week. just need to get injectors, intercooler another intake and tb
vashxj
Vehicle Year: 1999
Post by vashxj »
went to the track sat and blew up the spider gears lol, I have started gathering supplies to build a ford 8.8
Defcon92
Stroker Displacement: 4.2l
Post by Defcon92 »
Just go 9" I regret it every time I did my 8.8. Non-c-clip is a huge plus, even a 28 spline is slightly stronger than the 8.8 from specs I've seen. Disk are easy to swap from an explorer.
And the biggest plus? Drop out 3rds...maybe 3.55 for daily and 4.10s for track :cheers:
Users browsing this forum: Google [Bot] and 3 guests
