Keep blowing heads, dumping coolant.
Re: Keep blowing heads, dumping coolant.
woodjeep wrote:you think you would have seen coolant pouring from the front of the motor if only loose bolts
My thoughts exactly.
tadjack
Post by tadjack »
it wasn't pouring, but it was hissing out from the back of the pump, so i replaced the pump. already had the new one when i noticed the loose bolts, figured i'd use it anywya.
