Jeep XJ Stroker build
gummij
Vehicle Year: 2001
Vehicle Make: Jeep XJ
Vehicle Model: 4WD XJ
Re: Jeep XJ Stroker build
Post by gummij »
SilverXJ wrote:
gummij wrote:Read/think before posting. I did not say it needs to overheat. I said it was not so much of a problem unless it overheats.
I'm pretty sure you are the one who needs a reading lesson. The head is a problem irregardless if it overheats or not.
gummij wrote: Maybe I should also point out that i don't need basic lessons in IC engine mechanics.
It appears you may.
Sorry SilverXJ, but it is simply hard to take you seriously in this discussion after such a foolish comment. (using the old cam could increase CR).
gummij
Vehicle Year: 2001
Post by gummij »
jsawduste wrote: Read more and comprehend what is being offered rather then going on the defensive. The non TUPY has earned a reputation for a reason.
Yes, Therefore, I will not spend time or money on it, and only use it to be able to use the car while I'm porting other head.
gummij wrote:Sorry SilverXJ, but it is simply hard to take you seriously in this discussion after such a foolish comment. (using the old cam could increase CR).
You think the cam doesn't change the DCR? You do need a lesson in basic IC mechanics.
akadeutsch
Vehicle Year: 1981
Vehicle Model: CJ8
Post by akadeutsch »
I always thought that the TUPY head was the good one. The way that I remember it was that in ~1999 Jeep introduced the 0331 Cast head with much improved flow we can all agree. However the early 0331 heads (~99-00)are and always will be prone to crack. The TUPY designation was the new 0331 casting that fixed the problems with the original 0331 head. :cheers:
gummij
Vehicle Year: 2001
Post by gummij »
SilverXJ wrote:
gummij wrote:Sorry SilverXJ,...
No, I don't think the cam doesn't change the DCR , it does. Your input was on CR not DCR. will you please just stay of this trhead.
gummij
Vehicle Year: 2001
Post by gummij »
akadeutsch wrote:I always thought that the TUPY head was the good one. The way that I remember it was that in ~1999 Jeep introduced the 0331 Cast head with much improved flow we can all agree. However the early 0331 heads (~99-00)are and always will be prone to crack. The TUPY designation was the new 0331 casting that fixed the problems with the original 0331 head. :cheers:
Yes, 0331 and 0331 TUPY seem to be the best in terms of flows in the original condition. Im lucky to have both.
Now I might be thinking of putting 1.7 roller rockers on that original cam shaft. Is there someone with experience on it ?
Accordingly, it should give 5% more flow (0.4 to 0.5 lift) and will put the original 0331 "alongside" ported 7120. So it looks to be a well spent $500 in combination with the 0331 ?
http://www.jeep4.0performance.4mg.com/tech_specs.html
Ported HO head #7120
Valve lift (in)....0.1.......0.2......0.3......0.4 ....... 0.5........ 0.6
Intake flow .....68.4....132.6....185.4.....213.4.....216.5.....216.5
Exhaust flow....64.3....116.9....149.6....158.9.....164.8.....165.0
HO head #0331
Valve lift (in)..... 0.1......0.2 ...... 0.3 ......0.4 ........ 0.5 ...... 0.6
Intake flow.......59.4.....122.6.....171.1.....201.1......214.3.....218.4
Exhaust flow.....47.1......93.4......123.3.....140.9......147.0......149.7
The TUPY is the good one.
gummij wrote:No, I don't think the cam doesn't change the DCR , it does. Your input was on CR not DCR.
Really? Where is that? You are also using the term CR incorrectly.
NO, you don't get to tell me I'm wrong then tell me to stay out of a thread. Keep pushing it.
gummij
Vehicle Year: 2001
Post by gummij »
Thanks for the constructive post guys. I guess I'll have to stop here.
Users browsing this forum: Google [Bot] and 5 guests
