Stumble when cold
joeguyzxj93
Re: Stumble when cold
Runs a lot better now with the new injectors . Next question I have is I put a accel coil in should my plugs be gapped bigger than stock seems like I am getting a knock under load that wasn't there before coil ?
jeepxj3
- Vehicle Model: xj
That seems weird to get 'knock' with just a coil change. I would retry the stock coil and see if the knock goes away.
If I gap bigger than stock it seems to run worse and stumble.
Knock or ping?
I to would put the stock back in and see if it is still there. Then try the accel again and possibly reset the PCM.
joeguyzxj93
Ping mostly underpaid .uphill or rite before a downshift . Will try it this weekend . Trying to work out all the bugs on jeep . Seems like one clears another starts . Guess its that jeep thing
Users browsing this forum: Google [Bot] and 5 guests
