Quick question: 1990 renix stroker - does it work
JeepFan
I talked with Clegg Engine today about doing a stroker on my 1990 Renix-equipped Cherokee. (I will be using a 1994 donor block and head - retaining my Renix F.I., intake & exhaust manifolds, distributor, flex plate, etc.). He said that stroker motors using the Renix system have not been very successful. Does anyone know if it will work or not? Is there anything I can do to make it work well? Any info would be greatly appreciated! Thanks!!!
JeepFan
1990 Renix stroker - will it work?
I talked with Clegg Engine today about doing a stroker on my 1990 Renix-equipped Cherokee. (I will be using a 1994 donor block and head - retaining my Renix F.I., intake & exhaust manifolds, distributor, flex plate, etc.). He said that stroker motors using the Renix system have not been very successful. Does anyone know if it will work or not? Is there anything I can do to make it work well besides swapping out the Renix system? Any info would be greatly appreciated! Thanks!!!
the grey ghost
- Stroker Displacement: 4.611
- Vehicle Model: comanche
Re: Quick question: 1990 renix stroker - does it work
I'm driving a 1990 jeep Comanche eliminator with a 4.6 in it now, but a split second signal modifier 199.99$
JeepFan
Thanks grey ghost! What is a split second signal modifier, how does it work, and where can I ge one?the grey ghost wrote:I'm driving a 1990 jeep Comanche eliminator with a 4.6 in it now, but a split second signal modifier 199.99$
There are many Renix Jeeps running stroker engines. No problem at all.
the grey ghost
You buy it from split second, if you want the also have one with a built in map sensor, and one that will change timing, and 02 sensor modifiers/voltage clamps, but you need some basice electronic/wiring skills
Re: 1990 Renix stroker - will it work?
I don't know why they said that... but its not good \ reliable information.
There is no difference in reliability for any Stroker engine you build regardless of year range.
A Renix stroker can work just as well and be just as reliable as any other stroker.JeepFan wrote:I talked with Clegg Engine today about doing a stroker on my 1990 Renix-equipped Cherokee. (I will be using a 1994 donor block and head - retaining my Renix F.I., intake & exhaust manifolds, distributor, flex plate, etc.). He said that stroker motors using the Renix system have not been very successful. Does anyone know if it will work or not? Is there anything I can do to make it work well? Any info would be greatly appreciated! Thanks!!!
It seems that your plan is to build an HO stroker long block and use the Renix accessories/electronics. Nothing wrong with that. If your state doesn't require all the smog equipment for visual inspection by the Gestapo, you could use a '99+ curved runner intake manifold and delete the EGR system. You could also use a HO TB and modify your Renix TPS to fit (or make an adapter).
If you choose to retain the Renix intake manifold, you'll need to do some mild fettling to make it sit higher on the head for the ports to line up.
As far as the Renix electronics go, you can leave them untouched for the time being. Just add a set of blue top Ford 24lb injectors (either Cobra 5.0 or Ford Racing, cheap used in ebay) and run the engine for a while to determine if you'll need to enlean or enrich it. If it becomes necessary, a MAP adjuster will do that for you.
JeepFan
It wasn't a reliability issue, but a customer could not get his Renix-equipped stroker to run well. I just want to make sure that it was maybe an isolated incident and not the norm...Muad'Dib wrote:I don't know why they said that... but its not good \ reliable information.
the grey ghost
Just an example, my 4.6 Had 24lb ford racing ev1 injectors first, it ran solo rich when I started it it barely ran.but I opened the throttle screw a little and put a resistor on my coolant sensor. Then I ordered my split second signal modifier(computer map adjuster), runs great now.
So which is it? The company or the customer?JeepFan wrote:It wasn't a reliability issue, but a customer could not get his Renix-equipped stroker to run well. I just want to make sure that it was maybe an isolated incident and not the norm...Muad'Dib wrote:I don't know why they said that... but its not good \ reliable information.
Regardless, it sounds like whoever was building the motor either didn't do it right or had other issues. Re-iterating that it doesn't matter which model year range you choose.JeepFan wrote:I talked with Clegg Engine today about doing a stroker on my 1990 Renix-equipped Cherokee. He said that stroker motors using the Renix system have not been very successful.
JeepFan
He was saying that the customer could not get it to run right. It sounded like it might be a fuel delivery problem - that perhaps the Renix could not adjust itself correctly, even though the customer changed the injectors. After doing some searching though, I have a feeling that you're right and the customer had other issues. It seems that the consensus is that a stroker Renix motor can be made to work well - either with different injectors and/or using a Split Second signal modifier.Muad'Dib wrote:So which is it? The company or the customer?JeepFan wrote:It wasn't a reliability issue, but a customer could not get his Renix-equipped stroker to run well. I just want to make sure that it was maybe an isolated incident and not the norm...Muad'Dib wrote:I don't know why they said that... but its not good \ reliable information.
