couple build ?s
manche89
Stroker Displacement: 4.0l
Vehicle Year: 1989
Vehicle Model: comanche+
couple build ?s
Post by manche89 »
ok fellas 242 12conter weight crank and rods are of to c&p machine. should i have them chop the snout or just get the hardened washer for the HB? wheres a good place to get rod, main and head studs?
RenoF250
Vehicle Year: 1985
Vehicle Model: CJ7
Re: couple build ?s
Post by RenoF250 »
I would do whatever is cheapest. I made a washer out of AL on the lathe for mine.
For studs I would use Summit:
Main:
http://www.summitracing.com/nv/parts/ar ... /overview/
Head:
Rods:
I only replaced the head bolts and used the $25 Fel-Pro kit. I have never heard of a main or rob bolt breaking in normal use.
Re: couple build ?s
Use the stock bolts for the mains they are plenty. You would need a line bore if changing to studs. You can use stock replacement bolts for the head, but I am not impressed w/ their quality. I recommend the ARP head bolts.
