buying pistons and lost! please help.
manche89
Stroker Displacement: 4.0l
Vehicle Year: 1989
Vehicle Model: comanche+
Post by manche89 »
ok this isnt my first engine build just my first full blown jeep stroker build. last one was just a 258 crank and rods slaped in a std bord block. ill be using a 12CW 258 crank and rods. in a .030 2000 xj block. lookink on ebay for .030+ pistons and am lost on the listing some say 87-95 and some say 96-06 are these for all year 4.0s or do i need to buy pistons for a 96-06 sence im using a 2000 block? please help trying to buy them tonight thank fellas.
Re: buying pistons and lost! please help.
Either piston will work. The difference is the ring size. Get the ring set for the pistons you get.
manche89
Vehicle Year: 1989
Post by manche89 »
what do you mean ring size. i know if i get +0.030 pistons to get 0.030.
Defcon92
Stroker Displacement: 4.2l
Post by Defcon92 »
manche89 wrote:what do you mean ring size. i know if i get +0.030 pistons to get 0.030.
I believe he means some rings come with standard sizes & others use metric size rings. I oped for the "moly" total seal rings? Guess they seat better/quicker & total seal I guess was full circle? So it had less blow by? :huh:
rainman
I think I'll order a "tab"
Vehicle Year: 1995
Post by rainman »
Any pistons will work in any year block.
It's just the thickness of some of the the rings on the piston changed in 96.
So just order rings for whatever year piston you get.
Obd1 scanner.
Sydney Australia
Standard vs. Metric rings. If you look at the piston specs you will see what the piston takes.
RenoF250
Vehicle Year: 1985
Vehicle Model: CJ7
Post by RenoF250 »
I was told they also went from cast to hypereutectic in 1996.
You aren't buying factory pistons. Pick the over size, pick the alloy, pick the ring pack, pick the manufacturer, buy pistons.
See here: http://www.jeepstrokers.com/forum/viewt ... ?f=34&t=67
manche89
Vehicle Year: 1989
Post by manche89 »
well on ebay they have the over sized for the differnt year. anyways can anyone point me in a good direction for 30 overs. i know you get what you pay for but this is kinda a buget build and dont wanna spend 600 bucks on a set.
RenoF250
Vehicle Year: 1985
Vehicle Model: CJ7
Post by RenoF250 »
manche89 wrote:well on ebay they have the over sized for the differnt year. anyways can anyone point me in a good direction for 30 overs. i know you get what you pay for but this is kinda a buget build and dont wanna spend 600 bucks on a set.
What do you want? You can get cast for as low as $100, hypo for $200 and I got forged for $400.
Defcon92
Post by Defcon92 »
I went with 677s on accident in my 4.2l stroker. I wanted the 2229s but told my builder 677s on accident. The Difference was a .004 lower pin height but 2cc less dish. I lost about 1/2 a point of compression...no biggy.
I'm hoping to add in a m62 super charger kit soon so that little bit lower compression was actually helpful. I'm at 9.2:1 & 8.0:1 dynamic.
Users browsing this forum: Ahrefs [Bot], Amazon [Bot] and 1 guest
