my long drawn out street/strip xj build
vashxj
Re: my long drawn out street/strip xj build
I'm using the 31 spline 8.8 with track lok and 3.73 gears, there is a couple different styles of the 8.8
Defcon92
- Stroker Displacement: 4.2l
vashxj wrote:I'm using the 31 spline 8.8 with track lok and 3.73 gears, there is a couple different styles of the 8.8
Correct that was I was running. Explorer 8.8 with the tubes welded. 4.56 & a Aussie. Disk brakes.
vashxj
actually not trak loc, im going to run a mini spool. I wanted a full spool but the c-clip eliminators and axles cost more than I want to dump in it right now
vashxj
small update currently waiting on parts for the rear end, decided to go with the full spool, c-clip eliminators, 4340 chromoly axles, I guess from all my research I cant bolt my zj calipers to the 8.8 brackets and just use ford rotors, traction bars, switching back to 3.55 gears and im throwing new synchros and bearing in my ax-15
What are your plans for a traction bar?
vashxj
just using those bolt on Lakewood ones, not sure yet im still thinking about welding up a bracket and putting in links like the explorers have but for 55 bucks and bolt on the Lakewood bars seem like a better choice for my lazy side
vashxj
forgot to post pics of the axle swap so here is some and some other recent ones finally got my seats in too
and this is as far as I got with the s/c lol
How well does the spool drive on the street? Love your hood.
vashxj
its pretty horrible on turns and between that and the 6 puck clutch it make a lot of noise but its not really meant to be comfortable. she definitely like to drive sideways now
sly-jeeper
- Vehicle Year: 1994
Hey I started a stroker group on Facebook it has very few people and only people with strokers you and anyone else that has a stroker are highly encouraged to join
Be nice if your group had a name. Didn`t have much luck finding it.sly-jeeper wrote:Hey I started a stroker group on Facebook it has very few people and only people with strokers you and anyone else that has a stroker are highly encouraged to join
sly-jeeper
Jeep stroker's 4.xxx send me a friend request on facebook if you can't find it. Brennen St. Onge
crazygogo
- Stroker Displacement: 242 + .30 over
- Vehicle Year: 2002
- Vehicle Model: wj
just an amazing build and very kind of you to share your wonderful machine..
how is the supercharger system coming along?
vashxj
thanks I haven't done much with it yet I just got done replacing all the windows in my house and remodeling the dinning room so that has been taking up time and money but it will really start moving in the spring
embs2001
- Stroker Displacement: 4.0
- Vehicle Model: comanche
what size shot were you spraying?
1988 Comanche w/ m90
Build thread- http://www.naxja.org/forum/showthread.php?t=1118735
