High Idle
Re: High Idle
How exactly did you bore it out?
jdobbs
- Vehicle Model: wrangler
Re: High Idle
I ground out the extra aluminum to the gasket opening size
Re: High Idle
Did you grind all the way through?
jdobbs
Re: High Idle
No it is just a little more then flush with the opening above the butterfly
Re: High Idle
You might want to check that you didn't actually go into where the throttle plate sits.
You obviously have a leak some place so check everything you took off. Gasket, IAC, MAP sensor, TPS, any hose you had to remove, etc.
Users browsing this forum: Semrush [Bot] and 4 guests
