Beehive valve springs
Joshy
Post by Joshy »
Anyone seen or run these? http://www.ebay.com.au/itm/271194461307 ... 1423.l2649. He's got 100% feedback
100lbs at 1.650" and 295lbs at .550" lift. I messaged him and was told they'd have 265lbs at .470" lift. They can also be used with the later model valves/locks. Looks like an easy option with good pressures.
Retlaw01XJ
Vehicle Year: 2001
Re: Beehive valve springs
Post by Retlaw01XJ »
Nice! Says they're made by Performance Springs (PSI). They're located in Michigan. Here's their webpage:
http://www.psisprings.com
Walt K
Eastern Pa
jeepxj3
Vehicle Model: xj
Post by jeepxj3 »
That price almost seems too good?
100lbs at 1.65"seat and 265lbs at 0.470" lift. Is that too much?
Post by dwg86 »
Might be a good alternative to the MP springs. I emailed the guy to find out what the inner and outer dimensions are on the top and bottom. (to see if the springs will fit the valve seat pocket and the Jeep retainers)
akadeutsch
Vehicle Year: 1981
Vehicle Model: CJ8
Post by akadeutsch »
Man I just spent 300 bucks on the MP springs. I guess I should have looked here first.
Post by dwg86 »
I asked the guy selling these springs for inner and outer diameters of the top and bottom. I need to check to see if I have some extra stock retainers laying around to measure to make sure they will fit the springs. Or maybe someone can measure one. The inner and outer diameters are:
TOP O.D. 1.230
TOP I.D. .850
BOTTOM O.D. 1.310
BOTTOM I.D. .960
According to the ad, the stock retainers will fit so I'd assume the locks would too.
The seller is based in Queensland, Australia and the price is in Aussie Dollars.
Post by dwg86 »
This would be a great alternative to the MP springs, and the cost savings of being able to use stock retainers is a plus. I dont really see a need for chrome moly retainers on an engine that doesn't go over 5500 rpms and that has realatively low spring pressures.
jeepxj3
Vehicle Model: xj
Post by jeepxj3 »
dwg86 wrote:I asked the guy selling these springs for inner and outer diameters of the top and bottom. I need to check to see if I have some extra stock retainers laying around to measure to make sure they will fit the springs. Or maybe someone can measure one. The inner and outer diameters are:
TOP O.D. 1.230
TOP I.D. .850
BOTTOM O.D. 1.310
BOTTOM I.D. .960
They are not very 'Beehive' shape/taper- 1.230top-1.310bottom
Would these be better?
https://www.lunatipower.com/Product.asp ... 08&gid=192
str8-6
I think I'll order a "tab"
Vehicle Year: 2012
Vehicle Make: Hot Rod
Vehicle Model: T-27
Post by str8-6 »
Ordered a set,they should work fine with the new camshaft that will end up in the engine next summer: http://www.lunatipower.com/Product.aspx?id=1478&gid=287
.060 overbore,9.9 C/R ,ported 7120 head Offenhauser intake/Holley 600 and hedders,almost enough for a 1850 pound hotrod but only almost so 75-100 shot of nitrous are in the plans...
Stroker Displacement: 4.9
Post by jsawduste »
jeepxj3 wrote:That price almost seems too good?
Seat is OK but 365 at 470 is a bit high. Even worse as the lifts go up. I personally, would not run them.
Seat could be a touch higher, but that open load is quite a bit heavy.
I6FAN
Stroker Displacement: 4.2
Vehicle Year: 1987
Post by I6FAN »
He said 265, not 365. The website says 265 also. 365 would be high, but 265 not so much.
jeepxj3
Vehicle Model: xj
Post by jeepxj3 »
355 lb/in, is that a bit stiff?
Post by jsawduste »
Fat fingered it. I meant 265 all along. Yes 355/in is quite heavy. I like and use the Engle 593`@ 1.700 or sometimes 1.650 depending on end usage and cam ramp. Not a drop in but the pressures are a bit more inline with our inlines, LOL
