1.7 yella terra non adjustables. What's the lash supposed to
Defcon92
Stroker Displacement: 4.2l
Post by Defcon92 »
Gonna pull the valve cover tomorrow to fix a small leak (bent cover). And I wanna recheck the lash. Builder set it up before so I never knew the specs.
the grey ghost
Stroker Displacement: 4.611
Vehicle Model: comanche
Re: 1.7 yella terra non adjustables. What's the lash suppose
Post by the grey ghost »
I try to shoot for around .030 or thirty thousandths, mine are all + or -2 or 3 thousandths, the rocker ratio doesn't matter unless your changining to a 1.7 ratio from a 1.6 or vice versa, then you reset preaload, you pretty much reset preload whenever changing anything in the valvetrain that puts preload out of spec, how to know ahead of time takes experience with building the same engine
Defcon92 wrote: And I wanna recheck the lash.
FYI, Mechanical cams with solid lifters have lash, which is clearance in the valve train. Hydraulic cams have preload, no clearance.
Defcon92
Post by Defcon92 »
So what would the clearance between the roller & valve tip be called? I always thought it was valve lash lol.
You have a hydraulic cam. There is no clearance.
.030"-.060" preload is what you want on a hydraulic.
RenoF250
Vehicle Year: 1985
Vehicle Model: CJ7
Post by RenoF250 »
Lash is straight clearance with no tension. With a hydraulic lifter you should always have the tension of the spring in the lifter, that is the preload. The springs are not very strong so you can push on them and make clearance at the rocker tip.
