Synthetic for Stroker Suggestions.
- Muad'Dib
Has anyone converted their Stroker to use Synthetic oil? I have been waiting forever to start using Synthetic and now that I have 15000+ miles on the 4.7 I think I am ready to convert.
For break in and the first few oil changes I used ZDDP Plus and Comp Break in Oil.
Afterwards, I started using Valvoline VR1 with ZDDP Plus and eventually just Valvoline VR1 by itself. From the start I have used 10w30.
I know in the past when I looked into this Shell Rotella T6 5w-40 was a good oil choice, but am not sure if that's still the case or if there is something better out there. Additionally, I am not sure if 5w-40 is appropriate for my engine.
Thanks for taking the time.
Re: Synthetic for Stroker Suggestions.
Brad Penn 10w-30
Haven't lost an engine yet due to lubrication issues.
From the cold of the North to the heat of the desert.
NelsonATC
- Vehicle Year: 1980
- Vehicle Model: CJ7
Mobil 1 15w 50
No issues, but don't run it much in the winter either
FlyinRyan
Rotella T6
purple_jeep
- Vehicle Model: GC
I have been using synthetic since the start, with the comp cams additive for cam break in.
Amsoil SAE 10W-40 Synthetic Premium Protection Motor Oil
http://www.amsoil.com/shop/by-product/m ... code=AMOQT
Has the zinc etc to help with engine life.
Now I only have 400 miles on the engine so not sure if I am a good data point just yet
Cheers
Chris
Cheers
Chris
Brad Penn, Joe Gibbs. and Amsoil also offers some high ZDDP oil. As do other leading synthetic companies.jsawduste wrote:Brad Penn 10w-30
- cruiser54
- Vehicle Model: Comanche
Here's an interesting read on oils from a fellow Jeeper:
http://www.cherokeeforum.com/f2/rotella ... ng-188168/
www.cruiser54.com
www.cruiser54.com
- cruiser54
www.cruiser54.com
www.cruiser54.com
akadeutsch
- Vehicle Year: 1981
- Vehicle Model: CJ8
I was under the impression that we did not want to use synthetic oil during the break in period of any engine. Conventional oil is supposed to help the rings and lifters seat. With 400 miles on it I would switch to a conventional for the next 10,000 miles or so.purple_jeep wrote:I have been using synthetic since the start, with the comp cams additive for cam break in.
Cheers
Chris
- cruiser54
Many new vehicles come from the factory with synthetic oil.akadeutsch wrote:I was under the impression that we did not want to use synthetic oil during the break in period of any engine. Conventional oil is supposed to help the rings and lifters seat. With 400 miles on it I would switch to a conventional for the next 10,000 miles or so.purple_jeep wrote:I have been using synthetic since the start, with the comp cams additive for cam break in.
Cheers
Chris
www.cruiser54.com
www.cruiser54.com
You don't want to use synthetic for break in. Doesn't matter what most new vehicles come with (they also come with OHC or roller cams). You also don't know what may be different about the factory fill oil.
- cruiser54
I agree. Just trying to address the myth that synthetics don't allow rings to seat.
www.cruiser54.com
www.cruiser54.com
Yeah. Oil isn't that consequential for ring seating. Its more of the driving/break in method. None of this granny it BS.
- Muad'Dib
I went ahead and went with Rotella T6 as I originally had thought about.
purple_jeep
- Vehicle Model: GC
Cheers
Chris
I have just over 1000 miles on the engine now. I changed the oil at 500 miles still on the same synthetic amsoil. Should I be changing to conventional or at this point is it too late/does not matter.
For break in I did the 30 mins between 2-2.5k for the cam, oil change then about 10ish runs up to 50mph then coast back to 30 to seat the rings.
Cheers
Chris
Users browsing this forum: Ahrefs [Bot] and 3 guests
