Edelbrock 4.0L head soon to be available.
PseudoSport
Where's the "any" key?
Stroker Displacement: 4.0L Turbo
Vehicle Year: 1995
Re: Edelbrock 4.0L head soon to be available.
Post by PseudoSport »
Cheromaniac wrote:
6TIME wrote:The extra volume in the runners should let the strokers breathe much better as well :D It'll be interesting to see the dyno numbers when these heads get out to the public.
The intake manifold will be the limiting factor as far as intake port breathing goes. The late model curved runner manifold has smaller runners aimed at improving midrange torque, so they don't breathe so well above 4500rpm.
For over 4500 RPMs would the earlier style intake work better?
GRM Challenge 1995 2WD Cheorkee, 2,780lbs, 240k 4.0L, 50 trim T3/T4 turbo, MS1 EFI, 36lbs injectors, -2.5 degrees camber, Ford 8.8 3.73 w/LSD, 274 whp/322wtq, 12.98@100mph 1/4 mile
http://www.Facebook.com/JeepXJR
1982 AMC Spirit - Turbo 4.0L, 60 trim T3/T4, MS1 EFI
Stroker Displacement: 4.9
Post by jsawduste »
no
PseudoSport wrote:For over 4500 RPMs would the earlier style intake work better?
I doubt it. It's probably better just to fabricate a custom manifold with shorter/wider runners, a bigger plenum, and a flange for a 68mm or 70mm TB.
b2carpen
Post by b2carpen »
I just might bite the bullet and buy this edelbrock head down the road if I give up on my own head work. I really like their new chamber design along with leaving room for additional port work. I'm hoping price is not more than 1200 otherwise might be out of my budget.. I can't wait for you guys interested to get your hands on this with your own opinions!
Here's a pic of my reshaped chamber design, still in progress...
hot_rod_hooligans
I think I'll order a "tab"
Post by hot_rod_hooligans »
b2carpen
Post by b2carpen »
I'm guessing another few months before this is on the market.
Post by jsawduste »
No, buy it now
b2carpen
Post by b2carpen »
jsawduste wrote:No, buy it now
Where? The other day Rod and I searched everywhere to find this head for sale and nothing came up :huh:
Unless that's changed today, I'll search around again in a bit.
b2carpen
Post by b2carpen »
Just spoke with Rod, edelbrock said (via fb) they will have the head on the market 1st quarter 2015 .
str8-6
Vehicle Year: 2012
Vehicle Make: Hot Rod
Vehicle Model: T-27
Post by str8-6 »
I'm hoping,and waiting for a RPM- or Victor-version have anyone given Edelbrock a small hint yet?
jeepxj3
Vehicle Model: xj
Post by jeepxj3 »
str8-6 wrote:I'm hoping,and waiting for a RPM- or Victor-version have anyone given Edelbrock a small hint yet?
Exactly, or a CNC version with bigger valves.
Jim K in PA
Vehicle Year: 2005
Post by Jim K in PA »
b2carpen wrote:Just spoke with Rod, edelbrock said (via fb) they will have the head on the market 1st quarter 2015 .
That is also consistent with what Troy Hooker at Edelbrock told me after the SEMA show.
nicpaige
Consistent
Consistent
Vehicle Make: XJ
Vehicle Model: Sport
Post by nicpaige »
Has anyone worked out the CR for this new head on a stroker with 4.0 rods, KB 944 pistons at zero deck height?
Post by jsawduste »
Working with one of the 4500 spec drivers that was supposed to get the new head.
Last minute changes to the casting have delayed introduction till early next year. Select folks MAY have them in time for KOH but that is a show me not tell me proposition.
Post by jsawduste »
nicpaige wrote:Has anyone worked out the CR for this new head on a stroker with 4.0 rods, KB 944 pistons at zero deck height?
Same as a typical iron head.
Users browsing this forum: Amazon [Bot], Bing [Bot] and 3 guests
