PoorMans Builds......Not Again......
Off topic, play nice. No Nudity, Pornographic material etc..
Stroker Displacement: 4.9
Post by jsawduste »
Dino, can you revise your recipes for stroker builds ?
So many people are getting mislead. 99 out of a 100 have no idea what quench or squish is and the majority of those same folks will blindly put an engine together and then be disappointed in how it performs. Without ever understanding why.
The cost of 944`s has risen to the point that proper pin height/desired compression pistons are only a few bucks more. This is money well spent. Diamond, JE, Bulltear etc all have a much better way to go.
Knocking a bunch of material off the block and then trying to increase chamber volume (if that`s what you want) is counterproductive. Your comment of enlarging the chambers may make matters worse as it applies to evenness of fuel dispersment.
One fact you keep forgetting is that your fuel blending is much different then what we have here. While I am happy that your personal set up works well for YOU. It is very unfair to those folks whom do not enjoy the benefits you have in fuel quality. Nowhere in your "recipe" book do you address this fact. This misleads people to a false sense of performance and economy.
I am frankly sick and tired of all this Poormans recipe desktop dyno stuff that has to be refuted time and time again. :deadhorse:
Build it right or don`t build it at all.
Re: PoorMans Builds......Not Again......
I appreciate your comments John and I'll certainly look into updating my recipes to version 3. :) It won't be difficult to do 'cause I know the maths.
If it's true that the IC944 pistons cost almost the same as a set of custom pistons, it may indeed be more cost effective to take the custom piston route as this would also save on the cost of decking the block.
I hope that someday, a piston manufacturer will step forwards and make off-the-shelf pistons that have a 1.380" compression height for a zero deck clearance right-off-the-bat with a choice of dish volumes for various compression ratios e.g. 30cc for 9.0:1, 24cc for 9.5:1, and 14cc for 10.5:1.
jsawduste wrote: I am frankly sick and tired of all this Poormans recipe desktop dyno stuff that has to be refuted time and time again. :deadhorse:
How about this one? Still a poor man's but with a tight quench.
4.6L Modified "poor man's" stroker
Jeep 4.2L 3.895" stroke crank
Jeep 4.0L 6.125" rods
9.25:1 CR
Stock 4.0L camshaft
0.043" quench height
Ford 24lb/hr injectors for '87-'95 engines, Accel 24lb/hr injectors for '96-'04 engines, '98 Chevy LS1 25.2lb/hr injectors for '05-'06 engines
248hp @ 4900rpm, 306lbft @ 3250rpm ('87-'95 camshaft)
245hp @ 4800rpm, 315lbft @ 3000rpm ('96-'04 camshaft)
Post by jsawduste »
Awesome Dino, glad you did not take my comments personally as they were not meant to be an attack.
Both of your recipes would be great. In particular the first one with different dish volumes. Let`s hope that one of the manufactures gets on the bandwagon and steps up to the need.
Thanks again !! :cheers:
jeepxj3
Vehicle Model: xj
Post by jeepxj3 »
RaceTec and Bulltear pistons already does that.
Post by jsawduste »
jeepxj3 wrote:RaceTec and Bulltear pistons already does that.
:cheers:
http://www.bulltear.com/catalog/product ... cts_id=242 $475 per set of six. :worship:
Post by jsawduste »
:worship: x2 :banana:
