help with combo (4.6)
- Vehicle Year: 1989
- Vehicle Model: wrangler
my set up:
1993 4.0L block
1993 4.0L rods beamed and shot pinned arp bolts
4.2 crank (cw?) Still in yj
comp 239-4 cam kit
0603 head ls1 valves self ported
96-98 intake gasket matched
62mm tb
Doug thorley header
96-98 fuel injection (xj)
24lbs ford injector
what I want to know is what compression ratio and quinch do I want for 87 pump gas.
lookin at 2 different pistons..
ic944
OR
http://www.bulltear.com/catalog/product ... cts_id=242
thoughts???
my jeep is a spring over axle. It gets a lot of axle wrap... hp/tq numbers are not really the goal... just a nice sounding fuel injected yj with some extra cubes.
1993 4.0L block
comp 239-4 cam kit
62mm tb
Doug thorley header
24lbs ford injector
ic944
OR
thoughts???
Re: help with combo (4.6)
You'll need a tight quench (preferably 0.040"-0.050") and a DCR of 7.5:1 or less to have the best chance of running 87 octane gas.
If you haven't already ordered the cam, I suggest you change it to a 68-231-4 to get a more even spread of torque from 750-5250rpm.
The 4.2 crank in your YJ will be a 4cwt version with a short 54mm nose (same length as 4.0 crank) so it'll drop straight into a stroker without modification.
Thoughts on pistons??
Bulltear.silver03cobra wrote:Thoughts on pistons??
Ok.. so they are reputable?
I've heard a lot of good feedback on the Bulltears so the answer is yes.
Oh good.. so my understanding is if I use a 96-98 head use that intake... same with the 99+ is this correct... picking up a 96 grand head and up for 150.00 (valve cover, rockers, intake,injectors *24lbs* ,tb*stock* and wire harnesse)
The favored curved runner intake manifold that you want to use is found in '99+ WJs and '00+ TJs/XJs.
From '96-'98 the older log-style manifold that appears on all '91-'99 models (except '99 WJ) was used.
What's the best way to tune this set up
You're going to end up with this recipe and apart from using oversize injectors, you may not need a tune:
4.6L low-buck stroker
Jeep 4.2L 3.895" stroke crank
Jeep 4.0L 6.125" rods
Custom forged +0.030" bore pistons, compression height 1.380", dish volume 23cc
9.6:1 CR
0.043" quench height
9.6:1 CR
Cheromaniac wrote:Bulltear.silver03cobra wrote:Thoughts on pistons??
Or KB IC944
Bulltear= $475 Custom made to your specs!
KB IC944= $402 from RPM Machine. Will require decking of the block for optimum deck height/quench distance/compression ratio
http://www.rpmmachine.com/shop/index.ph ... ail&p=5972
Both use 4032 alloy.
Don't count on either of them being in stock, may take a few weeks to get them.
Walt K
Eastern Pa
Eastern Pa
Yea... I can wait... want it all done by end of may...
New question! !!! I can get a full wire harnesse from a 96 grand cherokee (Auto). Will this work?
