anybody done this.........
crazygogo
Stroker Displacement: 242 + .30 over
Vehicle Year: 2002
Vehicle Model: wj
Post by crazygogo »
http://www.ebay.com/itm/TDS-Jeep-4-0L-I ... 66&vxp=mtr
anyone heard of this throttle body swap?
Re: anybody done this.........
I have that adapter and the 65mm neck above throttle blade/68mm below 4.7l tb from an '01-02 WJ. I need to chop and weld the 4.0 throttle linkage onto the 4.7tb, remove 99+ intake manifold and open the 62/3mm hole to 68mm, chop and solder newer TPS connector tails to my '96 harness, figure out a 3.25"-3.5" elbow and 3.5" cone filter. Should definitely help the stroker to breathe.
shawnxj
I love this board
I love this board
Vehicle Model: cherokee
Post by shawnxj »
yup i created it with my machinist buddy. his screen name here is dott. have been running if for almost 2 years now i think
crazygogo
Vehicle Year: 2002
Vehicle Model: wj
Post by crazygogo »
kool so i won't feel alone here so got the parts just gotta weld check,,,, how is the pos and what are the cons of this upgrade>>??>>
shawnxj
I love this board
I love this board
Post by shawnxj »
no real cons that i can think of. took about 10 minutes to figure out where to weld the linkage. not sure what pos your talking baout
crazygogo
Vehicle Year: 2002
Vehicle Model: wj
Post by crazygogo »
glad to hear no cons.. pos.. like it added better throttle responce better mpgs etc etc..
shawnxj
I love this board
I love this board
Post by shawnxj »
much better throttle response and with that worse mileage because it's more fun to drive. it'll probably add a little more mileage since it's letting your engine breathe better and make a little more power but it's likely to be negligible
blacktj44
Stroker Displacement: 4.7l
Post by blacktj44 »
I just got done doing this mod and haven't had a chance to drive it around yet. I found a video on YouTube of a guy who made his own spacer. He showed how to do it all including the mods to the throttle body. It was great help. I bought the aluminum for the spacer locally it was like 10 bucks or so. Doesn't look as good as the one you can buy but who cares it works and it's covered up anyway.
I love this mod and highly recommend spending the $ on the quality adapter. Buy yourself a 3.5" cone filter and 3.25"-3.5" jdm silicone elbow and then find a 3.5" 45* piece that you'll put a nipple in for the valve cover breathing(I'm temporarily using a $5 adjustable 4" dryer vent that slips over filter and elbow).
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 1 guest
