SHOPPING LIST FOR MY STROKER BUILD
SOUTHY5678
Vehicle Year: 1989
Post by SOUTHY5678 »
I'm new to the stroker world, but I love this community already. You are all extremely dedicated to your machines. I have my donor 4.2 block, and my HO head from a 92 cherokee already. I'm just looking to build a bad ass stroker motor. I don't care if I have to run premium in it. I just want power.
I'm looking for a shopping list of parts . So if any body wants to help me out I'd really appreciate it.
Stroker Displacement: 4.9
Re: SHOPPING LIST FOR MY STROKER BUILD
Post by jsawduste »
4.0 block not 4.2
SOUTHY5678
Vehicle Year: 1989
I have both. I was under the impression the 4.2 was the better block to build from?
Post by jsawduste »
No. In fact because of the lower deck height I prefer to use 4.0 blocks 91 and up.
Go here
http://www.jeepstrokers.com/forum/viewforum.php?f=34
Some of the info is outdated as it applies to particular part numbers but the basics are there. Don`t get caught up to far in "recipes". Just use them as informative baselines.
There are a number of pretty old but smart guys on here. Do a little research on your own to grasp the basics. Us old guys will help out with particular questions.
K ? :D
SOUTHY5678
Vehicle Year: 1989
Thanks for the help. I will check out the Dino site tonight. I've got the 4.2 engine apart already. I might just build two of them for the fun of it. I feel like building this motor is a good idea, but wringing every little ounce of power might be harder than expected.
Post by jsawduste »
Dino's site is useful but again don't get hung up on particular specs
SOUTHY5678
Vehicle Year: 1989
Well, after much extensive research.......and on this site I feel like I'm back in college :geek: ....... I have decided to go with a basic build to start. I will use stock valve train items and build a basic 4.2/4.0 head stroker. This leaves the 4.0 HO block free for the winter to rebuild and bag for a future project. I will do a small amount of port/polish work to the head, and probably buy the new injectors. I feel that the main issues to address right now are getting a nice balanced flow from intake to exhaust with proper fuel management. Since I will be opening up the head I will probably scavenge a throttle body and have the lip milled. I have access to a small machine shop and a moderately experienced machinist almost daily. My wrangler has a few issues that need to be addressed in the mean time......suspension and re-doing the transmission lowering kit. Nothing to extensive, but it all eats away at the few precious months of summer up here in Maine. I definitely thank everyone on this site for all the info. You guys are amazing. :cheers:
Post by jsawduste »
a 4.2/4.0 head is not a stroker.
It is a 4.2 with a 4.0 head. That being said you will be very happy with the performance increase the 4.0 head will provide. Use the 4.0 intake/exhaust manifolds or a 4.0 header. Strongly consider upgrading to the 91-95 fuel injection over your present carb.
Recently helped a friend do this exact swap. Used the 91-95 cam and freshened up the head with new but stocks springs and such.
SOUTHY5678
Vehicle Year: 1989
I still plan on doing the stroker.....just not until the 4.2 is done. I will definitely switch to the fuel injection. One of my friends that put a 4bt in his cj is helping with all the stroker specs for a later build.
The 4.2 build is pretty straight forward I think. Which push rods did you use?
Post by jsawduste »
Even the factory used a number of different pushrods over the years. Only way to be sure is to use a PR length checker. That way you can dial in exactly what you need based on your combination of parts.
Summit 15 bucks or so.
