What injectors and throttle body are you using?dwg86 wrote:Those are great dyno numbers. What has been done to the engine...cam, pistons, valvetrain, etc...?
99+ Intake Manifold & Unichip Mods w. Dyno Results
Re: 99+ Intake Manifold & Unichip Mods w. Dyno Results
- Comanche91
- Vehicle Year: 1991
- Vehicle Make: JeeP
- Vehicle Model: Comanche
53030778 Mopar 23.2 lb. injectors and a 62mm bored out throttle body.
Amazing dyno numbers. Can you post the dyno charts?Comanche91 wrote:Got the 2001 WJ intake manifold mounted and the Unichip wired in on my 4.5L Hesco stroker and had the Unichip programmed and was dynoed at Hesco today; amazing results. The dyno peak HP vs. torque BEFORE readings last year were 207.5 HP @ 3950 RPM, torque was 243.0 at this RPM. Peak torque was 280 @ 3600 RPM. The AFTER reading, manifold only, was 219.5 HP @ 3916 RPM, torque at 294.9. The AFTER reading w. manifold and Unichip, was 261.1 HP @ 4400 RPM, with torque at 312.8. Peak torque was 345 @ 3500 RPM. All readings are at the rear rear wheel of course.![]()
That's a HP increase of 53.6 (although at a higher RPM, 3950 vs. 4400) and a torque increase of 65 ft. lbs. at about the same 3500 RPM, even w. the 20%-25% power robbing AW-4. Just the updated intake w/o the chip gave impressive gains. Very worthwhile mods.
- John
Outstanding! Why do I suspect this new found response will likely not improve realized mpg.
I found it interesting to see your 99 intake numbers. Torque increase was as I suspected but HP was higher. My butt dyno isn't calibrated as well as Lee's shop equipment. Good to see those numbers.
- Comanche91
Hi Dino. I don't have a scanner, but I'll drop the charts off at a friend's and have them do it, and will post tomorrow. Would like to have you guys comment on them. DonCheromaniac wrote:Amazing dyno numbers. Can you post the dyno charts?
Do you know what compression you are running? The LSA on the cam and where the ICL is installed? I am really impressed with this setup...261hp and 345 torque at the rear wheels! WOW, must be fun to drive.
- Comanche91
All I have is a lot of Hesco part numbers that don't mean much to me. If you call or email Bennie or Lee at Hesco, they can provide all the info for their HES4.5 engine, w. the RV-O-B cam, 1.6 valves, HESDP45030 piston set and HES9-3127 double roller timing set. It runs great on regular grade fuel with no pinging. Kyung, if you read this, you can probably fill in the compression ratio and cam LSA, since we have the same motor AFAIK (except you have the alloy head!).dwg86 wrote:Do you know what compression you are running? The LSA on the cam and where the ICL is installed? I am really impressed with this setup...261hp and 345 torque at the rear wheels! WOW, must be fun to drive.
- Comanche91
I suspect you are right John, but according to Hesco there have been quite a few feedbacks to them reporting increased MPG due to the more efficient burn w. the 99 intake and Unichip. But it all really boils down exerting self restraint on the olde skinny pedal I think more than anything. And yeah, the peak HP was higher than I expected too, especially at that RPM, which I seldom see.John wrote:Outstanding! Why do I suspect this new found response will likely not improve realized mpg.I found it interesting to see your 99 intake numbers. Torque increase was as I suspected but HP was higher. My butt dyno isn't calibrated as well as Lee's shop equipment. Good to see those numbers. John
What gear was the dyno run in?
- Comanche91
Mostly in AW-4 3 position; since the peak readings were in the 3500+ RPM range and 3 locks out the OD and allows the most precise RPM control.SilverXJ wrote:What gear was the dyno run in?
fishyjeep
Compression on your motor, Don, is about 9.4:1. LSA for the rvob cam is 110 degrees. I've got the h264 cam in mine which has a LSA of 114 degrees. Compression on my motor with the Al head is around 10:1. I sure wish I could get it over to hesco someday for a "custom" tune on their dyno. Maybe I'll make a roadtrip in the future.Comanche91 wrote:All I have is a lot of Hesco part numbers that don't mean much to me. If you call or email Bennie or Lee at Hesco, they can provide all the info for their HES4.5 engine, w. the RV-O-B cam, 1.6 valves, HESDP45030 piston set and HES9-3127 double roller timing set. It runs great on regular grade fuel with no pinging. Kyung, if you read this, you can probably fill in the compression ratio and cam LSA, since we have the same motor AFAIK (except you have the alloy head!).dwg86 wrote:Do you know what compression you are running? The LSA on the cam and where the ICL is installed? I am really impressed with this setup...261hp and 345 torque at the rear wheels! WOW, must be fun to drive.And heck yeah, it's fun to drive in the lightweight MJ.
- Comanche91
Thanks Kyung. Have you ever had a dyno run on your rig? I'd bet that alum head makes a heck of a difference.
fishyjeep
I wish, but no dyno run yet.Comanche91 wrote:Thanks Kyung. Have you ever had a dyno run on your rig? I'd bet that alum head makes a heck of a difference.
- Comanche91
Here are the dyno charts, with last readings superimposed. One is for the new manifold only, the other is the manifold + Unichip:
- Comanche91
Well, been running around all weekend hauling materials since we're installing new hardwood floors in the house (because the Commander wants them.Comanche91 wrote:Good question. TBD. Maybeseanyb505 wrote:Just curious, how will the Unichip affect gas mileage?or
. I'm hoping the latter.
So it looks like back to Hesco next week for some more UniChip tuning. I'm thinking it may be tuned too aggressively? Buy dayem, it flies.......
