Replacement upgrade for fuel pump on 2000XJ
nicpaige
Consistent
Consistent
Vehicle Make: XJ
Vehicle Model: Sport
Post by nicpaige »
I did a search and didn't find the info I was looking for so heres my question. I'm planning on dropping the gas tank in the near future and since my stroker is coming together I will be swapping out the stock pump while I have the tank down. On my other vehicles I have always had good luck swapping a walbro pump unit into the stock module but I cant seem to find a walbro part number for a 2000XJ. I see the Aeromotive at the link below but its a 340lph which is way overkill and Im worried about it causing problems with the internal regulator. Does anyone have any suggestions for a 190 or 255 lph replacement pump? thanks
http://www.summitracing.com/parts/aei-1 ... l/cherokee
Re: Replacement upgrade for fuel pump on 2000XJ
Edit: stay away from Airtex(my bad).
If Wallbro you want the GSS342 (255LPH) pump and the install kit 400-869.
I decided to give a company called Deatschwerks a try for my 255 fuel pump. I'll be installing it this weekend with a new regulator to get that POS Airtex out of it.
http://www.deatschwerks.com/
nicpaige
Consistent
Consistent
Vehicle Make: XJ
Post by nicpaige »
Thanks for the information!
